1972 Starter Brace
1972 Starter Brace
I had to replace the starter on my 1972 cutlass, however the replacement starter does not have the tapped hole to attach the starter brace. Can I drill and tap a blind hole approximately 1/2" deep into the case? Are there any implications such as interference with the rotating components inside, or electrical issues that may arise due to this change?
Thanks,
Thanks,
I would take the starter apart to drill the hole - you do not want to drill into the stator coils.
Or, you could take the starter back and tell them you want one with a hole in it.
Thanks,
Thanks,
We've all left this PITA off at one time or another, but there are two good reasons to reinstall it. First is the obvious structural one. The starter is not exactly light and without the brace, there's a signficant bending load taken out by the aluminum nosepiece and starter bolts. The more important reason is starter ground path. Without the brace, the only ground path for the starter is from the steel case through the aluminum nosepice to the iron block. Aluminum and ferrous metals suffer galvanic corrosion, which will eventually cause too much resistance in the ground path and hard starting. The steel ground strap bypasses the aluminum starter nose and provides a better ground path.
X2. The only reason not to simply rebuild the original starter is if the windings are burned out or the commutator is badly worn. Fortunately, these events are pretty rare. Usually all it takes is brushes, starter drive, and a new solenoid. Of course, most auto parts stores don't stock these parts anymore, only rebuilt starters. You can get the parts but you have to wait to order them. Same problem with alternators.
Actually Joe, up here I can get that kit (and did) when I redid mine. My solenoid was ok though but I did take it apart and reconditioned the copper disc and cleaned up the copper poles in the cap. Not hard at all.
Thanks, the original case had a crack at the seam along the bottom and could not be salvaged. The internals have been restored. I feel that in keeping with the historic and mechanical properties, the brace will be re-installed.
I installed the brace on my starter for the reasons above and also I thought it would help shield the starter from some heat from the exhaust pipe.
Also if I remember my Z bar return spring attaches to the bracket.
The previous owner had the spring attached to one of the exhaust pipe studs.
Joe
