1972 horn button removal
Old Sep 9, 2010 | 01:11 PM
442b's Avatar
M
Old Sep 9, 2010 | 07:20 PM
Originally Posted by 442b
My 72 Olds 442's horn does not work. Unfortunatly, here in Massachusetts we need our horns working to pass mandatory inspection. I have power at the horns, have not checked power at relay yet (because I just learned where it is). I would like to remove the horn button on the steering wheel but don't want to break anything. Does anyone know how to remove it. I think there is a contact problem behind the button. Any help would be great!! Also, does anyone know where I can obtain downloadable wiring schematics? Thanks again, Brian
Which kind of steering wheel?
Old Sep 9, 2010 | 07:57 PM
442b's Avatar
H
Old Sep 9, 2010 | 08:01 PM
Eric Anderson's Avatar
It just pops off. A spring tension type clip holds it in place.
Old Sep 9, 2010 | 08:04 PM
442b's Avatar
S
Old Sep 9, 2010 | 10:31 PM
71 Cutlass's Avatar
One of None W-31
NO !!! Just use your fingers. Screwdriver could slip scratch something etc. This thing just pops right off. Get your fingers under the edge and pull up...presto it comes right off..NO TOOLS ! I don't want you to experience the bad luck I have, by using tools when they are not necessary and just end up scraping,stabbing, or cutting parts that never needed anything other than just a simple tug. Hopefully my misfortune can turn out to be a positive help for you.
Old Sep 10, 2010 | 06:29 AM
442b's Avatar
H
Old Sep 10, 2010 | 06:56 AM
Hmmmm, I tried just using my fingers on it yesterday & didn't have any luck. That's why I stopped & decided to post the question here. I'll give it another try today. Thanks for the info.
Use a piece of wood or plastic, like a paint stir stick. Alternately, wrap your screwdriver in electrical tape first.
QS442
Feb 19, 2020 07:21 AM
rmoths
Mar 30, 2013 12:15 PM
bulldog
Oct 18, 2010 09:26 AM
millwrightrice
Sep 2, 2008 08:09 AM
millwrightrice
Tech Editor's Desk
Aug 31, 2008 06:04 AM
