1971 Cutlass Supreme Convertible Top relay location
Old Dec 1, 2022 | 08:45 AM
Roger1971's Avatar
Can anyone tell me the location of the convertible top relay? I don't see it in my service manual. Any pictures?
Old Dec 1, 2022 | 08:51 AM
In engine bay on firewall. I might be able to find a picture. Location can be found in the Product Information Manual (PIM)
Old Dec 1, 2022 | 08:58 AM
Roger1971's Avatar
Thanks Norm. Under the power brake booster? Does the orange/black wire from the switch through the firewall and connect there?
Old Dec 1, 2022 | 08:59 AM
https://classicoldsmobile.com/forums...relays-161922/
Old Dec 1, 2022 | 09:01 AM
Well, I posted from a 1969 model series (by mistake) but it should be same - I think? Probably not - my luck.
Old Dec 1, 2022 | 09:04 AM
1971 PIM "power top" circuit breaker
Regarding wire colors, I'd have to look them up on the CSM (can't recall from memory).
Old Dec 1, 2022 | 09:49 AM
Roger1971's Avatar
Thanks. This helps a lot
Old Dec 1, 2022 | 10:00 AM
If your intention is to spend modest to significant amounts of time, you should get a PIM. I have one as do many. Reach out to Hairy Olds, he has exceptional PIM products. He doesn't have one listed on this thread, but ask him anyways.
1968 to 72 A-body PIM
Old Feb 18, 2023 | 08:39 PM
oldsonharmont's Avatar
Convertible Top Circuit Breaker
I'm researching old posts about convertible top circuit breakers (relays). While shopping for a replacement part, I've found circuit breakers available in both 30 and 40 amp models. Can anyone here confirm which value is correct?
Old Mar 29, 2023 | 10:38 AM
Did you find an answer? I "think" my Power Top switch has gone Tango Uniform - not 100%; albeit, I'm starting w/ examination of the circuit breaker itself (which is HEAVILY corroded) - it may or it may not be the issue. None-the-less, I just removed the circuit breaker & recall this post you having asked this question. I cannot say if GM Oldsmobile used two different sizes of circuit breaker neither can I say if they used one size for a particular electrical load nor another electrical load. With that said, my '71 CS convertible has Power Top & power windows. I see two wires on one post leading into my circuit breaker. Haven't looked at the wiring diagram with detail at this point (I'm sure one of the wires is the Power Top I suspect the other is Power Windows) - I do not have Power Seats.
With all of that said, my circuit breaker is 40A. I suspect I'll find the actual part number after I clean it up real good & I'll post that number if I find it. Manufactured by LITTELFUSE, INC.
Old Mar 29, 2023 | 11:14 AM
Falkon's Avatar
My '71 Cutlass Supreme has both the power top & power windows. I've researched the wiring & it appears the firewall mounted breaker has one wire direct from the horn relay distribution block, & two wires from the other post entering the cabin. One looks like it goes directly to the top switch, & the other to the power window relay in the left kick panel. This is gathered from the car itself, as well as both Factory Service Manual, & Fisher Body Manual. I'd wondered about the amperage of that breaker also, & never found a specific reference. Great information.
Al
Old Mar 29, 2023 | 11:21 AM
Pretty sure those are the two correct wires you described.
Part # on the 40A LITTELFUSE INC is 111.
Old Mar 29, 2023 | 12:12 PM
Falkon's Avatar
I began tracing the car's wiring shortly after I bought it. There didn't appear to be a fuse as indicated for the high speed blower relay. Someone had just patched the two wires together. My concern after looking at the wiring / breaker, behind the brake booster, was that the wire to the interior had begun to melt. After a closer look, it seems to be water proofing goop the factory used at the grommet.
Old Mar 29, 2023 | 01:03 PM
Oh well, my circuit breaker demonstrates perfect continuity although I did clean it all up including the posts & wire terminal ends. The Power Top SW is FUBAR - flops around like a limp dick. Looking forward to removing the speedo & fuel cluster guages for an R&R.
Old Mar 29, 2023 | 01:24 PM
Falkon's Avatar
I removed mine to replace all the IP bulbs after I bought the car. 1971 Cutlass. Switch is pretty much below the gas gauge. That one & my clock came out easily. Good luck. I've not done my top switch (it was replaced by the PO) but could you access it from below if you remove the A/C duct? I pulled off the duct to work on my fuse panel. Just one screw.
Old Mar 29, 2023 | 02:07 PM
Al - Thanks. I've been into my dash a couple dozen times for various reasons. Should be straight-forward. Thanks.
yammy
Feb 10, 2022 06:03 PM
JVCCutlass
Jun 22, 2021 12:04 PM
carlos77062
Sep 11, 2017 12:03 PM
70-Olds-442-convt
Mar 6, 2017 07:54 PM
Delta88Royale
Mar 28, 2014 07:25 PM
