1970 Cutlass Ignition coil location
Old Aug 23, 2021 | 04:36 PM
Rustbucket2's Avatar
When I put this car together , I had no idea where the Ignition coil is to be mounted! I have aftermarket intake. This is where I mounted it, with a spacer to set above valve covers, but under air cleaner. can someone show in a picture where it is supposed to go on a 1970 350.
Old Aug 23, 2021 | 05:11 PM
The factory intake has a drilled/threaded boss for mounting the coil bracket. It would be in the same general area where you have your coil mounted, but on top of the intake.
briane
Sep 2, 2019 01:23 AM
briane
Apr 12, 2013 05:46 PM
navvet
Feb 18, 2011 08:27 PM
al714
May 1, 2010 03:12 PM
matt68
Sep 11, 2009 05:19 PM
