1970 442 A/C wiring diagram
Old Aug 15, 2024 | 02:13 PM
alain's Avatar
Question 1970 442 A/C wiring diagram
Hi all looking for a A/C wiring diagram under dash for my 1970 442
I seem not to have one.Any help or tips welcomed
Alain 1970 442 4spd factory A/C
Old Aug 15, 2024 | 02:17 PM
A/C wiring diagram is contained w/in the 1970 CSM in the back w/in the accessories section.
Old Aug 15, 2024 | 02:21 PM
alain's Avatar
No have one of those
Alain
Old Aug 15, 2024 | 02:24 PM
Then to be honest you're out of luck. I as well as others have posted the A/C wiring schematic elsewhere on this site. I think I posted the 1971 diagram which I think is identical to 1970. Have you tried a search?
Old Aug 15, 2024 | 02:31 PM
I can't find my A/C wiring schematic anywhere. Perhaps more explanation of what you're attempting to troubleshoot/accomplish we might get you more information. I guess you're convinced it's electrical, but are you sure it's specific to the A/C or is it possible the blower motor is involved?
https://classicoldsmobile.com/forums...-power-176088/
Old Aug 15, 2024 | 03:15 PM
alain's Avatar
The A/C system is all new trying to get the fan to engage
Alain
Old Aug 15, 2024 | 03:17 PM
When you say fan, are you referring to the blower? What fan? The radiator fan? Is the heater blower operational?
Old Aug 15, 2024 | 03:21 PM
alain's Avatar
Referring to the blower fan
Alain
Old Aug 15, 2024 | 03:27 PM
Is the blower fan operational at all? IOW, does the blower fan engage when set to heat? Or, is it possible the blower fan is in fact operational but you're attempting to wire in the new A/C into the blower fan? If the latter is the case, is the A/C system an OEM A/C system or VintageAir, etc.?
Old Aug 15, 2024 | 03:57 PM
alain's Avatar
The A/C system is OE not a vintage system blower fan does not engage when set to heat
Alain
Old Aug 15, 2024 | 04:05 PM
OK. I'm not going to tell you I'm an expert on hooking up your A/C. I've been in it, done some troubleshooting, etc. yet...did you review the link I sent to you on the blower wiring?
Do you have power at Number 8 wire? Checked the 30 AMP fuse?
Old Aug 15, 2024 | 04:09 PM
You'll (obviously) need power on the Number 2 wire(s), as well. Checked the fuse in the fuse panel for power?
Old Aug 15, 2024 | 04:10 PM
alain's Avatar
I have power to the compressor may have to go under dash deeper to check wiring
Alain
Old Aug 15, 2024 | 04:13 PM
Alain
OK So, those diagrams I provided demonstrate power to the blower fan assembly/system. If the blower fan is not operational, I would think you need to resolve the issue of why the blower is non-operational in the heating mode to at least validate you can get the blower operational. Sorta providing you a patch to troubleshoot (hopefully).
Old Aug 15, 2024 | 04:17 PM
alain's Avatar
Thanks Norm you have given me a lot to work with.
The adventure continues
Again thank you
Alain
Old Aug 15, 2024 | 04:18 PM
Viewing your 1970 fuse panel (below link) demonstrates the first fuse (25 AMP) contains both the AC & Heater...that's a great place to start anyways.
https://classicoldsmobile.com/forums...source-147944/
Old Aug 15, 2024 | 04:20 PM
alain's Avatar
I have done that part
Alain
Old Aug 15, 2024 | 04:21 PM
Mr Shifty Sidney's Avatar
These are from the 70 Chassis manual. Good luck.
Don W
Old Aug 15, 2024 | 04:22 PM
Here's the 1970 wiring diagram from the 1970 CSM. It's very readable. Don't forget you can zoom into the diagram with your browser to make it more legible or d/l the diagram and use a program to zoom in. Others will likely chime in at some point & provide additional suggestions.
Old Aug 15, 2024 | 07:36 PM
twilightblue28A's Avatar
This is the laminated version?
Old Aug 15, 2024 | 08:28 PM
What?
Old Aug 16, 2024 | 06:10 AM
No, it actually isn't. It's in the A/C section, page 1C-12.
Old Aug 16, 2024 | 06:11 AM
Since A/C was an option, it's not shown on that wiring diagram.
Old Aug 16, 2024 | 06:24 AM
Yeah, my bad. Because I knew it was an option I stated it was in the accessories section. I was grabbing images from my Electrical>Wiring Diagrams folder. Thanks, Joe.
Old Aug 16, 2024 | 06:31 AM
My intent here wasn't to demonstrate any A/C wiring, but instead demonstrate at a minimum the fuse panel wiring and heater circuit to the blower fan since the OP stated he has no blower fan in the heat mode. Coupled w/ the Fig 1C-6 I was hoping to impart a basic overview to validate power w/in that circuit (maybe?).
Old Aug 29, 2024 | 03:06 AM
alain's Avatar
I would like to say THANK YOU to all for your guidance .
Problem solved it was the a/c fan speed switch that was bad
A bit of a challenge changing it but it is done
Again thanks to all
Alain1970 platinum 442 4spd factory A/C
brock1030
Mar 26, 2024 12:33 PM
Malcolm11
Mar 28, 2020 06:55 PM
Nop
Nov 21, 2016 04:06 AM
agrein8888
Mar 31, 2014 07:53 PM
AZ442
Jul 29, 2009 06:16 PM
