1969 stereo wiring
Old May 4, 2007 | 11:50 AM
69deltaconvert's Avatar
1969 stereo wiring
Ok I'm putting the stock AM transistor stereo back in the Delta. It has a three wire plug one labeled 12v (12v input easy one), the next is SPK (I assume speaker), the last is GD (now is this the speaker ground or stereo ground), and it has a blue wire that comes out of the tuner *** and runs down the passenger side this if for ????. Any help would be appreciated.
Old May 4, 2007 | 12:12 PM
Oldsguy's Avatar
Past Administrator
I have a 69' Delta wiring diagram at home so I will check for you to make sure.
Old May 4, 2007 | 04:40 PM
Oldsguy's Avatar
Past Administrator
I checked the diagram and it doesn't show any radio wiring. I don't know why. That is something I never noticed before. I hope you can get it from someone here though, sorry.
Old May 5, 2007 | 05:13 AM
ozoneblue's Avatar
If I recall the blue wire is for lights.& use the radio chassis for ground
techcote
Dec 25, 2012 08:53 AM
Jokers69
May 1, 2007 04:16 PM
Olds luvr
Dec 13, 2006 02:59 AM
88oldz
Nov 28, 2006 03:58 AM
