1969 Cutlass Tail Light Issues
1969 Cutlass Headlight Switch
Looking for some assistance. I have a 1969 Cutlass and I’m trying to remove the headlight switch bezel so I can remove the actual switch. I have the **** off. That was easy just push the pin in and pull it out. Now how do I get the actual bezel off?
I've usually just used a needle-nose pliers with the jaws opened to insert into two of those notches to unscrew it. If it's really tight you can use a small screwdriver or punch in one of them and tap it with a hammer to loosen.
andrewk94
December 9th, 2014 12:17 AM
