1968 Ignition Switch Connector
Old Mar 13, 2019 | 04:17 PM
bry593's Avatar
1968 442 Convertible
I searched, didn't find a significant answer.
As you know, 1968 was a transition year. Federal mandate required a key minder buzzer, so the 1967 switch was redesigned two incorporate two additional terminals dedicated to the key minder circuit. In 1969, the feds required a steering lock and the ignition was completely redesigned and moved to the column. Unfortunately, this makes 1968 a one year only design.
My ignition connector must have overheated at some point because it has been replaced with the bare type 56 and a few PIDG terminals. The rest of my dash harness is in fairly good shape, so would prefer to fix this portion. My problem is that I cannot find a 3-prong, 1968 connector housing. Evidently, it is not reproduced even though it should be same as Chevelle.
What is the solution? Perhaps use a 1967 ignition and connector while disabling the key minder circuit?
What is used on aftermarket factory fit dash harnesses?
-Brian
Old Mar 13, 2019 | 07:27 PM
steverw's Avatar
You might try calling Lectric Limited,i have their harnesses on my 67 Olds, and on my Vette.
American Auto Wire, i have not personally used them but have heard good things about them.
Perhaps they can tell you if the plugs are available.
Steve
Old Mar 14, 2019 | 04:57 AM
allyolds68's Avatar
-Brian
Are you looking for the plastic piece that houses the wires and plugs into the back of the ignition switch? If so I probably have a few. I'm sure Scott Winn (oldspackrat) has a hundred of them too
Old Mar 14, 2019 | 10:14 AM
bry593's Avatar
Yes, that is what I need. Please send me a pm if you can sell me one.
Old Mar 14, 2019 | 02:16 PM
allyolds68's Avatar
Per your PM request. This is mounted kind of behind the Master Cylinder. I can't remember exactly where but I know it's just above that grommet that's shown in the drawing below
Old Mar 14, 2019 | 06:19 PM
allyolds68's Avatar
I sent you a PM also but I don’t have one that I can sell. Send Scott a PM. He’ll have one. Sorry about that.
Old Mar 15, 2019 | 07:06 AM
bry593's Avatar
Thanks, that is helpful. You know I saw that page in my book and didn’t realize what i was looking at. I think I have an extra 30 amp breaker that looks similar enough to use.
I did send Scott a PM. Hopefully he’ll have the elusive connector housing.
Old Mar 16, 2019 | 07:30 AM
bry593's Avatar
Thanks for sharing Scott's contact. He was able to help out and that just made my Saturday!!!
1968_Post
Sep 5, 2015 08:46 AM
1968_Post
Sep 3, 2015 10:57 AM
68442gal
Mar 14, 2015 08:46 AM
gearheads78
Dec 3, 2012 09:29 AM
WhatIf
Feb 10, 2012 06:44 PM
