1966 Olds Chassis Service Manual - circuit diagram
I am referring to page 12-2 of this manual which is the Wiring Diagram for the Cutlass V8. I am wondering if I have a misprint in my manual.
In the schematic for the headlights, my manual shows one high beam on the right inside(as you look at the diagram). I believe this is the way it should be, but the Left High beam is shown on the outside which I don't think is right. Even the wiring is colour coded as I have described above.
Any advice on this matter would be appreciated.
I'm seeing a tan wire going to the two low beam filaments and green to the four high beam filaments, which is as it would be on the car. Not seeing the problem here.
Not to sound like a smartass, but what else, if anything, on that wiring diagram is in position relative to actual location on the car itself?
Be glad Olds saw fit to use color-printed wiring charts. The other Divisions used black on white line drawings- even Cadillac.
BeenThere
July 17th, 2018 02:02 AM
69442murph
March 25th, 2013 07:59 AM
MaxDog
July 21st, 2011 11:50 AM
