1965 Delta 88 HEI conversion
Old March 9th, 2005, 07:38 PM
JoshF85's Avatar
Post
What wires do I use to feed power to the HEI?
Do I join the wires together that run to the points coil? I know I'd have to replace the resistance wire with a non resisitor type? Anyone point me in the right direction?
Thanks!
JoshF85 is offline
Old March 11th, 2005, 05:16 AM
jdorour's Avatar
Post
Connect the hot lead from the ignition switch to the power terminal on the HEI Cap. I think it's the outer front terminal (but you better double check). that is the only one you need to connect unless you have a Tach - then you will need to hook that wire to the TACH terminal on the cap. Make sure you have a good ground on the block and the body to ensure the module will last.
jdorour is offline
Old March 14th, 2005, 04:14 PM
JoshF85's Avatar
Post
Do you know what color the wire is I need to replace/use to power the HEI or what spade on the ign switch it is?
Thanks!
JoshF85 is offline
Old March 15th, 2005, 10:50 AM
jdorour's Avatar
Post
I do not know the color.
It is the hot lead from the ignition switch to the coil (not the one from the coil to the dist).
jdorour is offline
joepenoso
June 4th, 2014 01:56 PM
oldscruiser
February 15th, 2011 12:44 AM
buds68a77
Tech Editor's Desk
December 2nd, 2009 08:01 AM
Frankenpez
February 8th, 2009 07:38 PM
Quick Reply: 1965 Delta 88 HEI conversion
