1964 cutlass ignition help
Old Apr 30, 2023 | 07:13 AM
Kirby1's Avatar
I have a 64 cutlass convertible automatic with factory center console. I can not get the car to start from the ignition but can jump it at the distribution block under the hood.
I pulled the ignition switch and tested it as best I knew how. I have connectivity between the power in and the ignition wire when I roll the key to start.
Is there a park safety switch in the console by chance?
Thanks for the help
Old Apr 30, 2023 | 07:24 AM
Yes, there is a neutral safety switch on the shifter in the console. Before tearing everything apart, try a little troubleshooting. Near the base of the steering column you'll find a connector with two purple wires. This is the connection to the neutral safety switch on column shift cars. There should be a mating connector with two purple wires that runs to the console NSS. Unplug this connector. Temporarily jumper the two terminals in the connector that goes to the dash harness. The car should start. If not, the problem isn't in the console. If it does start, now check for continuity between the terminals in the other connector that runs to the console. If you don't get continuity, try slowly moving the shifter to see if there is continuity in other positions. If so, the switch is mis-adjusted. If not, either the switch or the wiring is bad and the console needs to come apart.
Old Apr 30, 2023 | 03:04 PM
Kirby1's Avatar
Thank You!!! I am able to get continuity in neutral but only if I push just right on the shifter. The car turns over with the jumper installed.
Guess it's time to take a console apart...this one year shifter thing has me very very nervous
Old Apr 30, 2023 | 03:14 PM
The same shifter and console was used 1964-66, but the pot metal at the top of the stick is VERY easy to break.
70 ctls
Sep 6, 2022 06:11 PM
Dwilla
Jul 19, 2022 11:22 PM
dewwhy
Oct 27, 2018 11:18 AM
Rickys61
Mar 20, 2014 03:48 AM
