1964 cutlass circuit breaker
I have a 64 cutlass convertible. I took the dash out to chase down a melted accessory position on the ignition harness. Been like this for 10 years. Car has power top, power seats and power windows. The power window harness has an additional offshoot of wires near the heater controls. These wires are blue, red and white and terminate in a plug that is the same shape as the power top switch. This plug was not connected when I pulled the dash and I cannot find a switch to connect it to. For some reason in the past someone jumped the blue and red wires in the plug. When traced the blue and red wires appear to go to the circuit breaker. Couldn’t find any wiring diagram that shows these wires. Anyone have any ideas on why this plug is present and jumped? Car ran normal and all electrical functioned properly. Seeing how these are hots wires with a jumper and no function I’m thinking of removing the connections from the breaker. Thanks for any insight.
Sorry, Joe. i meant to type power windows in the original post. Updated that post. Reviewed the 65 Assembly manual and indeed found a relay on that circuit. Assume it to
be the same for 64? Correct me if I’m
wrong. I’ll have to search for the specific relay type. It’s a 3 pin plug.
I took it apart and cleaned the contacts for now. The car is unfortunately a ways from being done. I'll replace it eventually, likely with a newer generic relay since it isn't visible. The car won't be totally stock anyway.
