1954 rocket 88 Brake light issue
Old Aug 18, 2015 | 10:41 PM
ortarheel's Avatar
Question 1954 rocket 88 Brake light issue
My brake lights don't work. My tail lights work and so do the blinkers. I check all the fuses and they seem OK. Is the tail/brake light switch mounted on the very bottom of the steering column? If so, mine might not be connected (wires cut).
Any ideas or links to wiring diagrams? Thanks!
Old Aug 21, 2015 | 05:33 PM
therobski's Avatar
I don't know much about a 54, however the brake light switch is activated when you press on the brake pedal, it opens the current turns on the tailights. Let off the brake the circuit closes lights turn off, same application for later cars with cruise control-same principal. If the wires are cut you now know-have a shop manual with the wiring diagram? Find the other end of the cut wires under the dash some where? Just some thoughts.
NINETY_EIGHT_REGENCY
May 18, 2014 07:12 PM
ozoneblue
Oct 30, 2008 11:30 PM
dan68toro
Aug 12, 2008 11:27 AM
john hyer
Jul 27, 2008 01:48 PM
ozoneblue
Dec 28, 2006 12:12 AM
