'73 Delta88 Diff Identification blank??
Old Feb 10, 2014 | 07:54 PM
73aussie455's Avatar
Acceleratii maxim rapidus
Question '73 Delta88 Diff Identification blank??
I'm trying to identify all the bits on my '73 delta and have drawn a blank IDing the diff. I've looked at the tech pages but can't find any info that relates to my '73 Olds.
The codes stamped on the diff (location found on the tech pages) are;
KA B283 1
the diff has a 10 bolt rear cover.
If possible I'd like to find out the size, type, gear ratios and whether or not its a posi diff. ( I dont think it is but hey, you never know!)
Can someone help? Thanks for your replies.
Old Feb 11, 2014 | 11:36 AM
copper128's Avatar
Lt. Buzzkill (ret.)
If it's a factory 455 car, it's likely a P-type 8-7/8" (10-bolt cover/12-bolt ring gear)
If the car came with a 350, it might be a corparate 8-1/2" 10-bolt.
Pics would make an ID easier.
Old Feb 11, 2014 | 11:52 AM
copper128's Avatar
Lt. Buzzkill (ret.)
OK, looking at the codes in the 73 service manual (sect 4B-33), there is no KA code shown for a Delta 88.
However I'm gonna take a stab at this and say what you have is probably a 2.73:1 open 8-1/2" 10-bolt.
I'm guessing the K indicates an open diff 8-1/2" 10-bolt
the A in the 2nd position is consistent with a 2.73 ratio in all differentials used in the larger cars
Old Feb 11, 2014 | 12:12 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Here's a link to a scan of the differential ID page from the service manual:
http://tinypic.com/m/i2t0nn/4
Old Feb 11, 2014 | 12:16 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Was this car produced in the US for export?
If so, that could explain the discrepancy. The FSM may not have all information relevant to cars produced for non-US markets.
Old Feb 11, 2014 | 01:37 PM
Thanks copper128.
It's a factory 455, TH400 produced in Lansing may '73 for the US market. Imported into Oz 2002.
I'll try to get some pics today.
Old Feb 11, 2014 | 02:29 PM
Kennybill's Avatar
Just from my experience, two 1971 Delta 88's both 455 v2, each had the 8 1/2 corporate. One 1971ninety-eight but it was a 455 v4, it had the larger 8 7/8 gears. Was it because the 98 was heavier or the 4 barrel? Ken
Old Feb 11, 2014 | 03:35 PM
Thanks Kennybill for the info. How do I tell if its a v2 or v4 455 and whats the difference? It has the 4 barrel carburetor option.
Here are the diff pics. The last one came out reversed for some reason.
Old Feb 11, 2014 | 08:34 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Thanks for the pics.
As I suspected, the squared-off lugs underneath and the 2 parallel ribs on the side of the housing positively ID it as a corporate 8.5" 10-bolt.
And 4-bbl carburetor means exactly the same as 4v carb. The "v" is an abbreviation for "venturi".
Old Feb 11, 2014 | 10:05 PM
Thanks for that info, again a great forum to be part of.
Nothing special then, just a run of the mill 8.5" 10-bolt 2.73 ratio diff.
Old Feb 12, 2014 | 08:56 AM
Kennybill's Avatar
Maybe just the "heavier" cars (98's) got the larger 8 7/8 rearend. Was your a factory 4 barrel 455? Actually your lucky because different gear ratios are available for your rearend. The bigger one not so much. Ken
Old Feb 12, 2014 | 01:06 PM
I can't imagine a heavier car than my tectonic plate...
Yes it is a factory 455 4bbl
seanoo
Jul 11, 2014 11:41 AM
507OLDS
Apr 28, 2014 03:45 AM
Delta88conv455
Nov 21, 2013 11:03 AM
GoBigRed
Jun 7, 2008 05:11 PM
barquecat
Feb 12, 2008 07:12 AM
