no vendors
Old Jan 16, 2014 | 05:10 PM
71 delta88guy's Avatar
no vendors
There are no vendors for 3 inch exhausts for these cars,correct?
Old Jan 16, 2014 | 06:54 PM
Not unless someone makes them for a 71 Caprice.
Old Jan 16, 2014 | 07:05 PM
coppercutlass's Avatar
Chevy budget Olds powered
use and modify an exhaust for a 95 ss impala. I used this system for my dads b body although it is a later shorter 77 b body. usually you can extend the system in the center and since the system usually comes in flanged pieces you can make a nice extension with out all the jimmy rigging. Just a thought.
Old Jan 17, 2014 | 07:41 AM
Yeah, and except for the different wheelbase, width, frame, floorpan, and gas tank location, it's exactly the same as a 71...
If you're going to cut and weld, just get a generic 3" exhaust kit. A-body tail pipes will probably be close enough that you can modify them to fit. The intermediate pipes will need to be modified for length, muffler style, and position. Head pipes will need to be Olds-specific.
Old Jan 17, 2014 | 07:47 AM
I was not aware of that .
Old Jan 17, 2014 | 07:53 AM
So, you're looking to flow 1,500 CFM, with an engine making 680HP?
I'm impressed. Tell us more about your build.
Or are you just trying to reduce your performance while making as much noise as possible?
Or..., you can just go down to your local exhaust shop and have one made custom for about the same money and no headaches. My local guy is an artist.
Old Jan 17, 2014 | 04:38 PM
I'm quite certain the need is real. Why would someone spend the money needed to go with a 3 inch exhaust and be making 400hp? I'm going to build,install,drive for at least a 1k miles THEN I'll take a visit to a chassis dyno. With the 4l80 I'm using I'd expect some more than usual power loss but I don't care. I'm looking for a nice nasty bulletproof driveline I can beat the **** out of for many years to come.When the build is complete I'll post my combo. I still might change a thing or 2.
Old Jan 17, 2014 | 04:46 PM
Paladin31's Avatar
FWIW I had the local muffler shop form 2-1/2" front to back, installed, including the mufflers [only flowmasters], I supplied trumpets [for just under] $300
redvettemike
Dec 20, 2012 05:07 PM
stlbluesbrother
Mar 19, 2011 10:09 PM
1971 442 convert
May 9, 2010 09:50 AM
ctrain22
Oct 18, 2009 07:57 PM
68conv455
Site Suggestions
Feb 25, 2009 08:11 PM
