what is this called so i can get a new one....
Old Aug 19, 2012 | 09:11 PM
bdub217's Avatar
Kickin' It Oldschool
On my phone so sorry for making you click a link.
What's the proper name for this piece? It gets mounted to the driver side of the carb and the screw hits the throttle......it's part of the cruise control.
Old Aug 19, 2012 | 09:32 PM
What year and model is this?
I have no idea what it is but I'll post the pic that you linked to make it easier for everyone else
Old Aug 19, 2012 | 09:38 PM
bdub217's Avatar
it's off of my 85 delta 88 307. There's supposed to be a plastic retainer ring that goes over the lighter silver colored piece that the screw goes into. it's way extended in the picture and is non-functional as it is....i may tack weld it down in it'c correct position. i've also removed the bracket due to the bracket for this piece also is the bracket for the TRS (throttle return spring)
@allan
thanks for posting the picture.
Old Aug 19, 2012 | 10:26 PM
Highwayman's Avatar
It looks like a dashpot to keep the throttle from slamming shut too fast.
Old Aug 19, 2012 | 10:28 PM
ah64pilot's Avatar
I'm thinking it's the idle speed adjuster for the a/c...is that not right? When the A/C kicks on it pushes the plunger out to increase the idle speed? Maybe not...
Old Aug 19, 2012 | 10:41 PM
bdub217's Avatar
i cant find it anywhere online yet...... the vacuum line nipple goes to the servo......... ......*does more searching*
EDIT:
Throttle Return Check Carburetor Dashpot is the part.
Thanks guys.
I've unplugged the servo ATM b/c of the dashpot being broke, its also removed and the vacuum line is plugged...maybe ill test the cruise without the dashpot.
Old Aug 19, 2012 | 10:54 PM
henryk8398's Avatar
Hangin' out...
It's called an Idle Load Compensator (ILC). These are unfortunately discontinued. Only chance on finding one is at a wrecking yard or ebay. Can be tough to find, but not too bad. Some people used the same year 307 vin 9 idle stop solenoid and wire to the A/C as needed.
Old Aug 19, 2012 | 11:01 PM
bdub217's Avatar
ah okay ....thanks. and of course they dont make it anymore. ill fix the one i have, maybe.
Old Aug 19, 2012 | 11:08 PM
bdub217's Avatar
anyone against running it without ILC????????? just kinda of a PITA to fix this part IMO.
Old Aug 20, 2012 | 04:01 AM
ThePackRat's Avatar
Big Daddy No Bucks
I personally don't see the world coming to an end.
As mentioned ...
I'd just track down a standard electric one & tap it it in to a/c compressor power wire.
And FWIW ...
If you have any intentions of ditching the CCC stuff at any point ...
That vacuum type ILC would be pretty much useless anyway.
Tim305
Jul 17, 2015 08:58 AM
1yesfan
Nov 13, 2014 04:52 AM
Sarum
Nov 12, 2014 06:55 PM
Gsherman
Nov 5, 2014 03:05 PM
Col Wickham
Nov 19, 2009 04:58 PM
