95 olds dies intermittently at high speed
Old Apr 25, 2007 | 06:40 AM
clarablue's Avatar
where is diag plug on 95 olds 88 royal ,does it need scanner or will codes flash check engine light
Old Apr 25, 2007 | 09:14 AM
Oldsguy's Avatar
Past Administrator
It completely dies or just sputters? I don't know where the diagnosis plug is.
Old Apr 25, 2007 | 09:52 AM
clarablue's Avatar
olds that dies
It just dies on hwy twice in last few days,restarts after a couple of tries,changed fuel filter this am.works fine under full throttle this am.also ran fine both times on hwy after restart,
Old Apr 25, 2007 | 04:15 PM
ohiocat's Avatar
Diagnosis plug should be far under steering column for that car.Sounds like you have a intermittent sensor issue,ive been there,you need to go to a top notch garage that has diagnosis equipment that scans cycle after cycle for every sensor (reads like a ekg machine at a hospital )those hand held scanners that reads codes are nooooooo match for an issue like that on that car trust me,,good luck
Macadoo
Jun 24, 2014 05:36 PM
smcurro
Paint
Jan 29, 2012 02:31 PM
DSkeet
Jan 19, 2010 04:13 PM
emarkay
Nov 14, 2005 09:13 PM
emarkay
Dec 8, 2004 08:23 AM
