Vacuum line location
I need help with the vacuum lines on a 350 2 barrell from a 1970 88. I will call you asap if you can give me your number. Example, the rear outlet near the top of the carb and also the breather tube has an outlet. Also there is a valve attached to the intake on the front right of the intake. I think i have the vacuum advance right but u never know.
Thanks, my 1970 delta 88 is done now except for these hoses.
I just put 4 gas shocks and heavy duty coils all around and it sits nice.
