57 Front Bench Seat bracket
Old Jun 17, 2019 | 01:28 PM
ArDan5s7's Avatar
Dan
I'm hoping someone can take a couple of pictures for me showing how the front bench seat rails fit into the floor of a 57 Super 88 four door sedan. The seat I have is bolted onto studs that stick up from the floor on the front just like the back rather than sliding in like the stock rails do. Whoever had the car before me installed an electric that doesn't work so I want to convert back to a standard manual bench seat. I purchased some original seat adjusting rails but they slide in rather than bolt on in the front. Am I missing some brackets that the seat rails slide into? If so, do these brackets bolt to the floor and then the seat rails slide into them. If I could see a picture of a stock set up, I can see if the previous owner Mickey Moused something or I'm just missing some parts. Thanks in advance for any help. Dan
Old Jun 17, 2019 | 06:21 PM
Yellowstatue's Avatar
There are two bolts 3 3/16" apart hold a 'U' shaped strap that the seat rail slips into. No pic. Not the safest of ideas by to-days standard.
Old Jun 17, 2019 | 08:25 PM
ArDan5s7's Avatar
Dan
Thank you! I see the two bolts so that makes sense. I think I'll fabricate something a little stronger though. Thanks again for the quick answer!
Old Jun 17, 2019 | 10:44 PM
59-59-59's Avatar
I think I used these brackets sold new for tri-five Chevy easily found on that auction site
Old Jun 21, 2019 | 11:45 AM
ArDan5s7's Avatar
Dan
Thanks 59-59-59! I ordered the brackets you suggested and they're going to work. Even the holes for the bolts fit perfectly! Thanks again. Dan
Minnesotajeff
Jan 27, 2018 09:41 PM
Rocketbrian
Sep 17, 2016 07:27 PM
1968CutlassSupreme
Jan 31, 2014 06:26 PM
Al Graaf
Apr 19, 2013 07:29 PM
ctreutel
Jul 6, 2009 03:21 PM
