What's the name of this sensor?
Old May 22, 2015 | 04:54 AM
1lowdelta88's Avatar
Rookie
I was wondering if someone can help me out and tell me what the name of this sensor is so I can purchase one. Thanks guys!
Old May 22, 2015 | 05:34 AM
Various vacuum controls were located in that position in various models and years.
Since your photo is extremely low resolution, it is not possible to tell which unit is pictured from the photo alone.
Your Chassis Service Manual will explain its name and its function, though.
If you don't know what it is, why do you want a new one?
Old May 22, 2015 | 06:14 AM
Rookie
I have the service manual and I've searched the index and various chapters, but have come up dry. Here is the manual I have. mZcY7KtW0VFMG54rIr_AV3g.jpg
In that manual, there is an exploded view of the intake manifold 0900c15280080bed.gif the image has the thermal vacuum switch located on the left side of the water neck, and the water temperature switch located on the right side, but nothing for what I'm looking for.
My reasoning for wanting a new one is because the engine is out of the car and I'm currently "cleaning it up" (power washing, engine paint, headers, etc) I'd like to put the sensor that came out of there back in, instead of just plugging the port. The old sensor was broken off.
Old May 22, 2015 | 08:05 AM
For starters, post a close up of the sensor you are asking about. Once you upload the photo, you might want to verify that someone who's never seen your car can actually make out the thing you are asking about. You should also check the Cooling and Carb sections of your CSM, as vacuum hose layouts, along with thermal vacuum switches, are usually shown in those sections.
Old May 22, 2015 | 09:13 AM
As you have not told us which engine your car has, see pages 6C-25 to 6C-27 of your Chassis Service Manual.
Rookie
The quality of the first image was already adressed by MDchanic, but thank-you so much for mentioning it, yet again! The first picture was not mine, I found it on Google and used it because it showed the sensor I'm asking about.
The sensor I need is circled in red, next to it is the water temp switch.
Here is another image (not mine) of the location of the sensor I need.
Old May 22, 2015 | 09:19 AM
The location isn't the most important thing - they put different switches in that location at different times.
Also, the contours of that manifold look odd to me.
Do you have a photo of the whole engine?
Is it a 400, by any chance?
Old May 22, 2015 | 09:43 AM
Rookie
I apologize for not posting the year, my car is a 1975. I do have a picture of the whole engine but it might not be the best, I will check when I get back to my laptop. The engine could be a 400 I guess but all the parts I've been buying I've ordered them for a 455. Not sure what is and is not interchangeable
Old May 22, 2015 | 10:14 AM
A closer look shows that that IS an Oldsmobile manifold, though the framing and angle had me fooled for a moment.
If you have a 455, then the vacuum switch on the rightmost front corner should be a Choke Thermal Vacuum Switch (page 6C-26).
Its function is described on page 6C-43 (all of the emission control gizmos, in general, are described on pages 6C-32 to 6C-49).
Old May 26, 2015 | 05:51 AM
Rookie
MDchanic I can not thank-you enough. Those pages you directed me to were exactly what I needed. I ordered a sensor Thursday, and I'm just hoping it's the right one. In the picture, it was a 2 port which is what I need, but the part that threads into the intake manifold looked to be too big. Hopefully the picture was just an example pic, not the actual one I'm getting. Thanks again!
Old May 26, 2015 | 09:19 AM
Glad to help out!
schapman33
Aurora
Dec 8, 2008 07:49 AM
jaco
Jan 5, 2007 08:57 PM
bearls
Dec 17, 2006 06:37 PM
beebee007
Aurora
Aug 17, 2006 06:45 PM
DonFrost
Ninety-Eight
Jul 12, 2006 03:58 AM
