What type ATF?
Old Aug 10, 2014 | 02:47 PM
SavedbyHim's Avatar
What type ATF?
Hey All
It has been a while, but I am nearing completion of my restoration of a 1961 super 88. My question, what type of ATF to use, I know it says type A, but....
Also, what type of power steering fluid are you all using?
Many thanks
Rob
Old Aug 10, 2014 | 07:56 PM
Ozzie's Avatar
The 1961 Oldsmobile service manual says that the fluid should have the following designation: brand name, including the words "...... Fluid Type A", plus the mark AQ-ATF and number and a letter "A" embossed on top of can as follows: "AQ-ATF-number-A". Change every 26,000 miles. 5-1/2 qts. for a conventional drain; 6-1/2 qts. for a pan removal; 9 qts. for an overhaul.
The original designation is hard to find (maybe now impossible?). Here's one that's a "maybe": http://www.warrenoil.com/
The last time I changed the fluid in my '55 Olds Hydramatic (a long time ago) I used whatever Dexron was current at the time. It has worked well since then. I did a complete change at the time, including the hydraulic coupling (which became a torque converter in '56) to minimize any possible incompatibility between fluids. Currently, "synthetics" may be available for it.
The manual says to use Hydra-Matic transmission fluid for the power steering.
Old Aug 10, 2014 | 08:01 PM
redoldsman's Avatar
Proud Viet Nam Veteran
ATF works fine for power steering but I have gone to using power steering fluid. i don't know why, it just seemed like the thing to do. Whatever the latest Dexron (I think II) is what I use in my 54 Olds. Works fine.
Old Aug 10, 2014 | 08:13 PM
1971cutlas's Avatar
dexron iv (6)
Since 2006 model years ,gm uses dex 6 auto trans fluid which supercedes all previous auto trans fluids, and is backwards compatible.
see or google bulletin # 04-07-30-037e. So,if your car was equipped with dex II for example,and it is no longer available, you can use dex 6.Hope that helps!
Juve
L77F85
Drivetrain/Differentials
16
Nov 29, 2013 06:19 AM
Greg Rogers
Aug 17, 2013 07:10 PM
1969cutlazz
May 8, 2011 03:04 AM
craftsman1956
Sep 2, 2010 07:46 AM
<rebelyel>
Sep 3, 2004 09:30 AM
