What part do I need?! Engine mount troubles...
I ordered engine mounts for my 75 delta 88, which I thought had a 455 in it.
This is what they sold me:
When I removed the old mounts, this is what came out:
And as you can see from the pics, this is the part I need to replace! If anyone can please help me with a part number or anything It'd be greatly appreciated...
Have you considered using the Search function?
https://classicoldsmobile.com/forums...tion-list.html
That's the frame mount. You should not have needed to remove it. Put it back.
That mount is broken. In any case, the new Anchor mounts may not look exactly the same as your old ones, but they will work and fit correctly.
By the way, is that the same street that Archie Bunker lived on?
