What part do I need?! Engine mount troubles...
Old Jul 8, 2014 | 05:38 AM
1lowdelta88's Avatar
Rookie
I ordered engine mounts for my 75 delta 88, which I thought had a 455 in it.
This is what they sold me:
When I removed the old mounts, this is what came out:
And as you can see from the pics, this is the part I need to replace! If anyone can please help me with a part number or anything It'd be greatly appreciated...
Old Jul 8, 2014 | 05:43 AM
Have you considered using the Search function?
https://classicoldsmobile.com/forums...tion-list.html
Old Jul 8, 2014 | 06:20 AM
Well, first, you need to be EXACTLY sure which engine you have. All available Oldsmobile-sourced engines use the same motor mounts (Anchor 2328) for 1975, but your D88 COULD have come with a Pontiac-sourced 400, which uses completely different mounts.
That's the frame mount. You should not have needed to remove it. Put it back.
That mount is broken. In any case, the new Anchor mounts may not look exactly the same as your old ones, but they will work and fit correctly.
Old Jul 8, 2014 | 06:28 AM
True, but the picture of the old mount he posted is clearly one half of the correct Anchor 2328 mount whose picture he also posted (whose file name actually contains the string "2328").
By the way, is that the same street that Archie Bunker lived on?
Supernaut72
58
Nov 21, 2014 04:23 AM
MN71W30
Jul 11, 2009 06:09 AM
jensenracing77
Site Help
May 20, 2009 05:31 AM
tury801
Feb 27, 2009 01:52 AM
pompman
Oct 22, 2006 08:20 PM
