Water leak issue driving me crazy!
Old Jul 19, 2013 | 03:35 PM
DeltaDevil88's Avatar
I am having a issue that is flat out driving me nuts every time it rains outside when I get into my car the passenger side front floor carpet is soaked, I looked above the floorboard into the dash area and it was a little wet but it wasn't obvious to pinpoint how the ran water got in.
Anybody had or heard about this issue?
Old Jul 19, 2013 | 03:48 PM
Water leaks like that are the hardest to find. Basically someone needs to lay in the car and look under there with a flashlight, while someone on the outside sprays water in different areas.
Old Jul 19, 2013 | 04:07 PM
Yeah already snooped around with a flashlight but will try the 2 man approach.
Old Jul 19, 2013 | 04:12 PM
If it were from Wed's storms even my sons 2006 Mustang got water in it. That wind was horrible. First time his ever got wet.
Old Jul 19, 2013 | 04:27 PM
I wish it was just a 1 time thing but when it rains I know my passenger floor board is going to be wet, happens every time.
Should I worry about rust?
Old Jul 19, 2013 | 05:30 PM
Redog's Avatar
I vote the top windshield seem on the pass side. That's where it's coming in on this car and were it came in on the other one
Old Jul 19, 2013 | 06:55 PM
Yes rust will be an issue.
Old Jul 19, 2013 | 07:07 PM
Lady72nRob71's Avatar
If the inside of the AC box if clogged with debris, water will not drain from it during a rain and guess where it goes....
The cowl on these cars (and the G bodies) drain through the AC box and through a little drain flap at the bottom of the box.
You would need to crawl under the car to find it and it is not easy to find either.
Is the plastic screen at the top of the cowl vent intact? You might be able to see any debris in there with a good flashlight.
Check this out if the area around the windshield looks okay.
Old Jul 19, 2013 | 10:30 PM
Feel free to stop by or we could meet up my Plano neighboor
Old Jul 20, 2013 | 08:14 AM
mrolds69's Avatar
Behind the right side vent panel, there is a vacuum door assembly. The door assembly has caulking that goes around it and seals it to the metal. It's a common leak prob in AC cars.
Old Aug 3, 2013 | 04:48 PM
Greg B.'s Avatar
The seal of the heater/AC box to the cowl itself can also be a leak source. The box is sealed with strip caulk which dries out over time. When water breaches the seal it gets into the ventilation ducts and can end up on the floor inside the car. Even worse, long-term leaking around the box can rot the firewall/cowl sheetmetal, leading to more leaks. If you can remove the AC box enough to inspect, this is worth doing if for no other reason than to renew the seal.
gbody 442
Jul 24, 2013 07:41 PM
oldsca
May 21, 2012 08:50 PM
rl55s88
Oct 10, 2011 07:30 PM
jpaulwhite
Aug 21, 2010 06:08 PM
ow30442
Sep 2, 2008 02:51 PM
