Two Issues need advice
Old Sep 16, 2021 | 03:45 PM
Supernice88's Avatar
Art S
Without going into a long story, I found the idle vent valve on my carburetor to be upside down when compared to the manual when I was rebuilding it. Does anyone know if that would have caused the car to almost stall (and if gas pedal pressed fast would stall)?
Rochester 4GC
Idle vent valve cover - the rusty piece
The other problem is why would the Dwell angle change from 30 and go to 45? Could that happen from cleaning the points or am I looking at a failing distributor?
Old Sep 16, 2021 | 04:21 PM
OLDSter Ralph's Avatar
"Cleaning" the points can definitely affect the dwell. What did you "clean" them with ?
Old Sep 16, 2021 | 05:33 PM
That sounds more like a faulty accelerator pump. It's supposed to squirt fuel as the throttle blades open, and if it doesn't squirt enough fuel, the air-fuel ratio goes way lean and the engine bogs.
Art S
600 grit paper.
Old Sep 16, 2021 | 05:38 PM
Art S
Thanks, I'll take a look at that. As it is now when I look down into the carb I can see the gas spraying into it.
oldsmobilejim
Aug 13, 2023 08:57 PM
Kyron219
Apr 11, 2020 07:28 PM
gehrig44
Sep 14, 2015 08:47 AM
Olds Dad
Nov 30, 2013 01:26 PM
rlafash
Aug 22, 2011 12:40 PM
