Tire Pressure
Old Nov 3, 2008 | 01:37 PM
Satellitecentral's Avatar
Tire Pressure
Hey guy,s
Quick question , what should I run as tire pressure , on my 66 Dynamic 88
14x6 Tires I think ?
Old Nov 3, 2008 | 04:28 PM
Oldsguy's Avatar
Past Administrator
Go by the tire manufacturers' suggestion, it is imprinted on the tire.
Old Nov 3, 2008 | 06:51 PM
rocketraider's Avatar
Oldsdruid
With a radial tire, 32-35 psi. With an original bias ply or belted bias tire, 28-30.
You have a heavy car to be riding on currently available 14" tires. Somebody was commenting on a 66 Ninety Eight wearing white letters tires a few days back; odds are those were all the owner could find in anywhere close to the right size which is 225/75R14.
Cooper/Mastercraft and Hercules were about the only tiremakers left making a big 14" whitewall and neither lists that size any longer on their websites.
A 215/75-14 tire is too small for a full-size 60s Oldsmobile.
That leaves two options- outrageously priced reproduction tires, or having somewhere like Diamondback Classics make you a whitewall or redline on a new 225/70R14 tire casing. When mine need them again, I'll go Diamondback. I know too many people who've had issues and outright failures on repro tires.
Old Nov 4, 2008 | 05:56 AM
Oldsguy's Avatar
Past Administrator
Would it be feasable to go with 15" wheels and tires?
Old Nov 4, 2008 | 06:31 AM
I know my 1964 Olds 98 has 15 inch wheels. I think it currently has 235/75 R 15s. They are a bit too big and scrape on the front. But, since I am not driving it right now they work fine. I will have to replace them when I am ready to drive the car anyways.
Old Nov 4, 2008 | 06:34 AM
citcapp's Avatar
Crocker Tires makes a 235/75R/14 tire and so does Cooper that is the same size as the Original tire for the big cars from 1955 through the mid 60's. I have new set of 5 Wide whites on rims that I have for sale because I am going to 15" Wheels to clear my disc brake set up
Old Nov 5, 2008 | 03:01 PM
ChrisM's Avatar
Sorry to butt into the thread, but does anyone know how big of tires I can get on my '73 Delta 88? I have the stock 15" rims, but I think the tires look too small for the wheel wells. I am hoping that I can use the same rims(because I like the original wire wheel hubcaps) but put on some wider and maybe taller tires to give the car some thicker feet. I don't want to rub all over town though,, so if anyone knows how big I might be able to go, I would appreciate it.
Thanks in advance,
Chris
Old Nov 5, 2008 | 06:14 PM
Oldsguy's Avatar
Past Administrator
You want to use a 75 series tire then. They would be the tallest for any given tire width. I couldn't say for sure but maybe 225/75R15. I don't think you can get an 80 series but they would be even taller.
Old Nov 6, 2008 | 10:52 AM
csstrux's Avatar
Thanks in advance,
Chris
I had a set of 235/70r15's on a 68 cutlass temporarily, and they filled out the wells nicely. they are stock on the older s10's and got them as take offs. they would probably look better on a delta than they did on the cutlass.
foreverolds
Dec 1, 2012 07:07 PM
rmoths
Wheels and Tires
Feb 8, 2012 09:03 AM
jdana24
Wheels and Tires
Aug 14, 2011 11:05 AM
1970conv98
Ninety-Eight
Jul 9, 2010 07:19 PM
Doug69Cutlass
Apr 6, 2009 06:54 PM
