Steering Column, 56 olds
Old May 9, 2007 | 10:01 PM
rket56's Avatar
Talking Steering Column, 56 olds
In the process of changing from manual to power steering on my 56, I discovered I would also have to change out the column. I got a column from a 56 with p/s, and just happened to check out the center shaft; it seems to have quite a bit of "slop" in it; the bearings may be worn. I haven't taken out my manual column for comparison; it is still hooked up to the steering sector. But in looking at the shop manual, it doesn't look like an easy job to take it apart and get it back together again. Comments and suggestions welcomed.
Old May 10, 2007 | 05:10 AM
Don Cain's Avatar
That is quite an undertaking, I would suggest you send the ps gear box in to get it rebuilt before going to the work of changing. You won't be sorry. Yes, it will cost some bucks but it will be worth it in the long run.
Old May 10, 2007 | 09:32 PM
rket56's Avatar
Yes I agree on the rebuild, I have already located 2 places to rebuild the sector and the pump and provide new hoses as a package deal. Thanks, Chuck
Old May 24, 2007 | 09:45 AM
kaptmikey's Avatar
56 power steering
rket56,
I'm a new member and currently converting my 56 from drum to disc brakes and the power steering is next. Where did you purchase the proper power steering column, and what did it cost. Also who is rebuilding your steering box, and how did you find them. Thanks Michael
Old May 24, 2007 | 04:21 PM
Don Cain's Avatar
Mike, I do not have power steering, I have a 51 super 88 deluxe coupe but I contemplated putting power steering on it until I looked into how much work and money it involved. I was going to send the gear box to LARES, a company who,s name I found in Hemmings motor news. I knew a man who had a 52 parts car with power steering but he has since then sold it.
Old May 24, 2007 | 09:11 PM
rket56's Avatar
Talking 56 power steering column.
Mike, I bought mine from " Junkyard Jeff " in Dayton Ohio, paid 100 bucks for it. For the rebuild, I will be using either Powersteering Services Inc, www.powersteering.com or pumprebuilder@door.net . I found both on the internet. Be careful on the disc brake conversation, I bought a kit from a guy in Calif and I was not happy with the way it turned out. In my opinion his kit would lead to early spindle bearing failure due to not enough support under the bearing. I finally sent my spindles to "Jamco", not cheap but a really first class job.
Old May 27, 2007 | 08:56 AM
kaptmikey's Avatar
Thumbs up 56 brakes
Don,
Thanks for the heads up. I too, bought the kit from Mike in Cali. and I'm wondering about the longevity! Who is Jamco and if its all right with you I would like to call after Memorial Day. I'm working till Mon. night. Thanks
Kaptmikey
Old May 27, 2007 | 10:10 PM
rket56's Avatar
Talking 56 Olds column, disc brakes, etc.
Mike, feel free to give me a call and I will be happy to share with you what I have learned and my opinions about the disc brake conversion I mentioned. 815 226 9517, Chuck, rket56
Old May 28, 2007 | 08:33 AM
kaptmikey's Avatar
chuck,
Thanks,I'll call you on Mon. in the afternoon. Michael
Old Oct 25, 2007 | 06:37 AM
c.ostrander@sbcglobal.net's Avatar
Olds56
Let me know how you come out on the power steering conversion. I am planning the same thing.
Old Oct 31, 2007 | 05:02 PM
rket56's Avatar
Steering column rebuild completed. I will offer details as requested. An earlier more detailed account was submitted several days ago but did not show up in the postings?
starfire
Dec 9, 2021 08:21 PM
shamusj
Apr 27, 2021 05:45 AM
317Cutty
Jun 18, 2014 10:53 AM
ros6872
Mar 28, 2014 09:48 AM
oddball
Mar 4, 2014 06:42 AM
