Speaker size
3-1/2" though I've heard you can carefully fit 4x6. If the car ever had a factory radio it should already have speaker wires to the existing dash speakers. You'll need a very short Phillips screwdriver and a wide flat blade to pry the speaker cover out.
Popular as the B-body Caprice is, you may be able to find kick panel speaker pods. Caprice and Delta are basically the same car.
