Rpo y79
Old Sep 5, 2016 | 07:08 AM
Rpo y79
So I learned something today...
Since I'm not as familiar with the 1960s full size cars, I've been reading up on them. Imagine my surprise when I stumbled across RPO Y79 in the 1967 SPECS booklet.
Yes, that's Y79, Tach/Clock Combination, and per the photo in the 1967 CSM, it looks exactly like the 68-69 A-body Tic-Toc-Tach. I knew it was possible to install the 68-69 Rally Pac in the 67-68 full size dash, but I did not know that the tach/clock was a factory option (and WITHOUT the gauge cluster).
Old Sep 5, 2016 | 08:13 AM
70-442-W30's Avatar
344879M363895
I like reading through those options lists. So I take it that was one of the more rare options then? What are some of the other ones that are uncommon?
Old Sep 5, 2016 | 11:47 AM
lshlsh2's Avatar
71 cutlass convertible
So will you be adding this to your parts wanted list?
Old Sep 5, 2016 | 12:18 PM
'Cause one of those will be easy to find...
Actually, I was planning on the whole 68 Rally Pac installation. The 67 Y79 looks just like the 68 Tic-Toc-Tach anyway.
Old Sep 5, 2016 | 01:30 PM
1968_Post's Avatar
Part number 6457998
That was an expensive part then...1972 catalog shows it at $121.50, which is around $700 today.
Old Sep 5, 2016 | 02:02 PM
Originally Posted by 1968_Post
Part number 6457998
Yeah, not surprising. It was $78.99 if you checked the option box when you bought the car. Consider that in 1968 the whole Rocket Rally Pac (gauges plus tach/clock) was only $84.26 in an A-body. Interestingly, Y79 was not available on the 1968 Delta line.
Old Sep 6, 2016 | 03:45 AM
rocketraider's Avatar
Oldsdruid
I have seen ONE 67 D88 Custom with the tach and had the owner not had his Monroney sticker, I'd have called BS.
Old Sep 6, 2016 | 05:59 AM
Yeah, that has to be right up there with the 1967 8 track player in rarity.
GStr33tXpr3ss
Ninety-Eight
Jul 5, 2014 06:57 AM
Danny Boy
Nov 22, 2012 02:52 PM
1970cs
Aug 11, 2012 07:38 AM
mmurphy77
May 10, 2011 08:20 PM
The Stickman
Nov 28, 2008 05:13 PM
