replacement speaker
Old Sep 14, 2020 | 06:19 PM
golden rocket's Avatar
golden rocket
replacement speaker
I'm needing a replacement speaker for the AM radio in my 67 Delmont hardtop. The speaker is a 4 X 10 and 10 ohms. I have yet to find a 10 ohm speaker in this size, most are 4 or 8 ohms. I was trying to repair it from info on you tube, but the {arkinsons shakes made the tears worse, didn't release I had gotten so bad. Any help is appreciated.
Old Sep 15, 2020 | 06:43 AM
RetroRanger's Avatar
72 Olds CS
Opgi and maybe others have a 10 ohm spkr
https://www.opgi.com/mobile-electron...y-s240839.html
oops maybe here for a 4x10
http://www.turnswitch.com/speakers.htm
crutchfield has a 4x10 but its 4 or 8 ohms depending on wiring
https://www.crutchfield.com/S-dd4M3p...SABEgKpFPD_BwE
Old Sep 16, 2020 | 10:17 AM
Loaded68W34's Avatar
You can also buy a 6 ohm high power resistor to add to a 4 ohm speaker. I usually mount the resistor to the metal part of the speaker housing and wire it through the ground side. That way you can still use your factory wiring from your radio.
https://www.electronicsurplus.com/vi...ower-6-ohm-50w
Old Sep 16, 2020 | 07:47 PM
golden rocket
thanks for all the help and guidance. looks like I'll be calling turnswitch in very neaar future. stay safe y'all
Old Sep 16, 2020 | 08:17 PM
mrolds69's Avatar
X2, what Dean says...turnswitch.com I run them in all my cars.
adis
May 31, 2020 09:49 AM
jerseymike
Sep 22, 2012 07:40 AM
Bunser
Mar 21, 2012 04:36 AM
mmurphy77
Mar 6, 2011 03:16 PM
Flye
Aug 11, 2009 03:17 AM
