replacement speaker
replacement speaker
I'm needing a replacement speaker for the AM radio in my 67 Delmont hardtop. The speaker is a 4 X 10 and 10 ohms. I have yet to find a 10 ohm speaker in this size, most are 4 or 8 ohms. I was trying to repair it from info on you tube, but the {arkinsons shakes made the tears worse, didn't release I had gotten so bad. Any help is appreciated.
Opgi and maybe others have a 10 ohm spkr
https://www.opgi.com/mobile-electron...y-s240839.html
oops maybe here for a 4x10
http://www.turnswitch.com/speakers.htm
crutchfield has a 4x10 but its 4 or 8 ohms depending on wiring
https://www.crutchfield.com/S-dd4M3p...SABEgKpFPD_BwE
You can also buy a 6 ohm high power resistor to add to a 4 ohm speaker. I usually mount the resistor to the metal part of the speaker housing and wire it through the ground side. That way you can still use your factory wiring from your radio.
https://www.electronicsurplus.com/vi...ower-6-ohm-50w
