Passenger Door Will Not Open From Outside
Old Nov 22, 2017 | 05:51 AM
Biggwaukegan's Avatar
Guys I'm guessing the clip or latch inside broke or became undone. Is this a job I can tackle with basic tools?
Old Nov 22, 2017 | 06:24 AM
redoldsman's Avatar
Proud Viet Nam Veteran
You don't say what the car is but they are all about the same when it comes to inside door handles and window cranks. Go to the parts store and buy one of those tools for removing door handles and window cranks if you don't have one. There is not much to them but you will never get the handles off without one. You might also want to get one of those plastic tools to pull the trim pad off. After that it is just basic tools. Good luck.
Old Nov 22, 2017 | 08:31 AM
Year and model would help us provide you with useful info. The configuration of the handle and latch vary from year-to-year, as does the process for fixing this.
Old Nov 22, 2017 | 12:48 PM
VI Cutty's Avatar
The tool is easiest, but a couple quick and free tricks...
- use a large paperclip - look for youtube videos detailing how to bend the clip. This worked for me until I bought the proper tool, which is cheap anyhow
- use a small cloth, drag it up beside the shaft behind the crank until it catches the retaining clip. Very easy to do, just learned that one and employed it on my kid's Toyota which uses similar clip keepers.
Old Nov 25, 2017 | 12:55 AM
84 Delta 88 Brougham Coupe
Old Nov 25, 2017 | 05:39 AM
Would have been helpful to know that up front...
These cars use a short linkage rod from the handle to the latch mechanism inside the door. It has probably come off, likely due to the retaining clip breaking or rusting off.
tcolt
Nov 7, 2017 06:58 AM
Shingo
Jan 29, 2017 09:10 AM
bigdooly
Dec 17, 2015 06:03 PM
mauls
May 11, 2015 06:53 PM
66-3X2 442
Jul 14, 2011 06:28 PM
