Oversize tire recommendations
Old Jan 18, 2018 | 02:20 PM
1969 88 Convertible's Avatar
New wheels arrived today. Now I need to settle on tire sizes so my local shop can get them ordered.
I've narrowed it down to 275/60R15 or 255/70R15 on the rear 8.5 inch rims. 275 is wider and 255 is taller by one inch. Section widths are 10.7 vs 10.3.
For the front, either P235/70R15 or 255/70R15 .
Input from fellow D88 owners is much appreciated.
Old Jan 18, 2018 | 02:37 PM
Was unable to load pics in former post....
Old Jan 18, 2018 | 03:41 PM
235/70-15 on the front, 275/60-15 on the back. These tires are nearly the same diameter. I have the 8.5" TTOs with the 1" negative offset on the back. I have the 7" TTOs with 0.25" negative offset on the front. I fear the additional offset and width of the 8.5" wheels on the front will be a problem, especially if you go with the 255s.
Old Jan 18, 2018 | 04:45 PM
Oops, I somehow failed to mention that front rims are 7"
Old Jan 19, 2018 | 07:24 AM
I know from my 67 Delta that the 15x7 front and 15x8.5 rear wheel combo will fit and look great. As I mentioned, I've got 235/70s on the front and 275/60s on the back. You'll be very happy with that combo.
Old Jan 19, 2018 | 10:34 AM
Just got back from my tire shop and they are ordering a pair of 275/60r15 today.
They showed me a pair of NOS Firestone 255/60r15 that have been collecting dust on a rack in their small warehouse for a long time. They still have labels on the tread. They offered them to me for 25.00 each which I couldn't say no to. The tires are 27 inches tall so the front will be lowered slightly..going with black wall side out since white lettering wouldn't match..between fronts and back...
Old Jan 19, 2018 | 03:19 PM
oldsmobiledave's Avatar
My former Delta Royale Stance
235 70 15s up front and 275 60 15s out back with 2.93 gears.
Yes those are rims from a 73-87 square body GMC pick up.
Old Jan 19, 2018 | 03:21 PM
Very nice!
To the OP, I'd be worried about the date on those $25 tires. Even stored indoors and not exposed to UV, they might still be a concern. I've had an old tire come apart while driving. You get a lot more sensitive to that after it happens to you.
Old Jan 19, 2018 | 04:02 PM
Great looking car and wheels
Old Jan 25, 2018 | 05:43 AM
P275/60r15 rear
235/70-15 on the front, 275/60-15 on the back. These tires are nearly the same diameter. I have the 8.5" TTOs with the 1" negative offset on the back. I have the 7" TTOs with 0.25" negative offset on the front. I fear the additional offset and width of the 8.5" wheels on orthe front will be a problem, especially if you go with the 255s.
Finally got the tires and wheels mounted. Will try to post pics..Body work starts next. I am removing all unwanted body trim including wheel well trim...
Old Jan 25, 2018 | 05:46 AM
P275/60r15 rear
P235/75r15 front.. Slighty taller tire rsised front end a bit
Old Jan 25, 2018 | 08:45 AM
Car looks very nice with those, but I'm biased when it comes to the TTOs.
Old Jan 25, 2018 | 04:18 PM
eric66's Avatar
Nice job great look.You painting the car the same color?
Old Jan 25, 2018 | 04:32 PM
Actually, thinking of upgrading to a more modern version of that color in a basecoat/clear coat. Two of my faborites are Lexus Bamboo Pearl from approx 2007. Or Jaguar Jade Green from mid nineties.. I also like 1968 Cadillac Green...so not decided yet...
Old Jan 25, 2018 | 07:44 PM
I love those wheels, had them on my Plymouth.
80_cutlass
Feb 7, 2016 12:02 PM
chip-powell
Apr 9, 2015 02:08 PM
w-30dreamin
Oct 14, 2014 08:51 PM
wabasto
Mar 14, 2014 08:37 PM
rootney
Jul 31, 2013 05:40 PM
