Need Help ASAP With Window Sweeps!!!
I have a 75 delta 88 I'm replacing the window sweeps on and I'm stuck on the rear quarters. When I bought the car there were no sweeps on the door panel it just looked like this:
So I bought a set of sweeps from eBay and I have no idea where the blacks clips go:
If someone can help me that'd be great! I was thinking I might have to do what I did with the others, which is drill small holes in the sweeps and use the original staples, but IDK please help! This is holding me up!!
![Frown](https://classicoldsmobile.com/forums/images/smilies/frown.gif)
I know this is an old thread, but having made the same quest, steele makes these sweeps and Convertible top specialists at www.topsdown.com has them as a regular item in their catalog.
With clips as those, the sweeps fit into the metal of the door which is opposite to the door panel. Should have two small Philips screws, one at each end. The door panel sweeps are held on with staples originally.
matchek
September 27th, 2012 01:13 PM
