Need 1955 "88" help
Old Feb 8, 2009 | 03:46 PM
1arunem's Avatar
Need 1955 "88" help
Hi guys, I am needing some info on my 1955 Olds 88.. Today what sounds like the water pump started making some noise. I believe the bearing are gone in it. It looks like it simply unbolts around the perimeter (bolted to the timing cover) after removing the fan. Is it that simple?
Also, I need a source for a replacement pump.
Thirdly (is that a word?), the fuel pump has two lines coming off of the top of it. These appear to be vaccuum. Is this correct?
Thanks!
Warren..
Old Feb 8, 2009 | 04:43 PM
ozoneblue's Avatar
55 Olds
is it a 324 ? if so not a hard job & yes one is a vac line going to the pump : Parts NAPA stores can order it dont expect them to have on there shelf
Old Feb 8, 2009 | 05:21 PM
1arunem's Avatar
Yes, it is a 324, sorry I should have stated that. I assume both lines on top of the fuel pump are vacuum? They go to a tee and then to the wiper motor..
Never seen it set up that way, but hey if it works..
BTW, I put 1955 by mistake.. it is a 1956..
Old Feb 8, 2009 | 05:34 PM
redoldsman's Avatar
Proud Viet Nam Veteran
If NAPA does not have it, try Fusicks. They are nothing but Olds stuff and are good guys as most Oldsmobile people are. NAPA will probably have it and I would try them first.
Old Feb 8, 2009 | 07:15 PM
citcapp's Avatar
Another mail order house to try is Rock Auto. Good people to do business with
bigrockingd
Jun 1, 2016 06:00 AM
4naffairs
May 27, 2013 05:50 PM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
martine
Jan 22, 2009 01:13 PM
