More post-winter issues!
Old May 8, 2012 | 07:25 PM
BStone's Avatar
OK so a couple more potential issues following todays drive...
First, my car is low...I mean real low. No, it was not lowered by teh 90 year old guy I got it from! The lowest point on the car seems to be the tailpipes and the mufflers. I am wondering if I got sme bad *** spring sag. How far off the ground should my great beastie sit: say from the frame just in front of the rear tires to te ground?
Secondly, tonight I parked on a slight angle along a curb with the passenger side of the car a bit lower than the driver side. Noticied a steady drip of fuel coming from the gas tank, source unknown but looked like somewhere from up top of the right front of the tank. About an hour later it seemed to have stopped and back home in the drive way could not replicate (more level). Gotta a pretty full tank and was wondering if this could have been coming out of the sending unit? The angle was not steep by any means
Thanks as per guys!
Old May 9, 2012 | 06:31 AM
jaunty75's Avatar
Can you remind us again what car you have?
About the fuel leak, it could be from the vent ports. There are often one or two short lengths of fuel line attached to the ports and routed up under the car where they terminate. This is to prevent fuel from leaking out of those ports, and if the vent lines are cracked and old or just missing altogether, you might get a leak like this, especially if the tank is full or near full as you say. Those vents are often on the right-front side of the tank, so if the passenger side was lower than the driver side as you say, that would only increase the likelihood that fuel would come out of those vents.
It's unlikely to be a leak at the sending unit itself as that's usually right on top of the tank.
The only way to tell for sure is to get under there and look.
Old May 9, 2012 | 04:33 PM
BStone's Avatar
Thanks for the info re the vents Jaunty. My beast is a 67 Delta 88 2 door with a 425.
Think I'll swap the coil springs and shocks out of it as I am sure they are a bit saggy.
Old May 9, 2012 | 04:57 PM
m371961's Avatar
Chassie manual should give info on ride height and where to measure.
Old May 9, 2012 | 07:25 PM
jaunty75's Avatar
I thought this was the case, but I wasn't sure. I have the same car, except it's a convertible. But the vent system I described is what's on my car, so it's exactly the same on yours. I would guess that your gasoline leak is very probably from one of the vent ports on the right front corner of the tank.
Old May 9, 2012 | 07:44 PM
jaunty75's Avatar
As far as ride height, yes, the chassis service manual shows that it should be 9.65 inches between the ground and the bottom of the chrome trim piece (not the bottom of the frame) measured at a point directly below the leading edge of the front doors.
The other place it shows to measure is at a point 70 inches behind the point above, and the height should again be 9.65 inches.
Old May 9, 2012 | 11:07 PM
BStone's Avatar
Brilliant, thanks guys. Just back from work so will be checking in the morning
OK so I am sitting at 7"
Hark442
Mar 16, 2016 06:25 AM
cutlassrichard
Sep 25, 2013 04:31 PM
stratoblues
Brakes/Hydraulic Systems
Aug 28, 2012 11:59 AM
MN71W30
Jun 2, 2010 01:51 AM
silverriff
Apr 14, 2010 09:49 PM
