Manual Trans for 1962 Dynamic?
Anyone know of an easy manual trans swap for the '62 Dynamic 88? Just off the top of my head I was thinking about the M-22 Muncie rock crusher but have'nt found any info online yet.
Thanks.
Thanks.
M-22 is a nice, heavy duty trans, but with the 2:20 to 1 first gear, would like be starting out in 2nd gear, with any rear ratio numerically lower than 3:90 to 1.
M-21 has a 2:54 1st gear, and would be much better for a 5000 + car.
Had done that switch on a '67 Impala SS 396, and the owner couldn't believe it was the same car!
Night and day difference!
The later 4 speed big cars (64-66) used M20s, probably better to get a big beast moving from a stop. No Muncie will bolt up behind a 394, unless an adaptor plate of some kind is used:
![](http://desmond.imageshack.us/Himg23/scaled.php?server=23&filename=transnr.png&res=landing)
Clutch linkage on those cars is pretty "funky" and is not going to be easy to find, so you might have to go with a hydraulic clutch, too.
6inarow
August 27th, 2019 11:22 AM
KidCutlass62
September 23rd, 2014 03:20 PM
TECH9TWISTA
July 7th, 2011 07:42 AM
