Loud "ping" when I stepped on the brakes
Old Jan 16, 2014 | 07:57 PM
Redog's Avatar
85 Delta 88 2Dr
OK Yesterday I when to change the rear drum brakes. I take the drum off and I still have a lot of shoe left, so I adjusted the brake and put the drum back on. Had to use a hammer to tap it back on. A few taps, not hitting like breaking rocks.
Took the car to work last night (2.5 miles each way) no issues
Took the car to Walgreens today (about 1.5 miles) Park, buy stuff, come out, start car, release parking brake, push foot on brake pedal and I hear a loud "ping" from the adjusted wheel and the brake pedal goes down a little futher. "Brake" light on the dash lights up right away with the rapid warning chiming.
Drove the car home, brakes were kinda like a "two stage" process. I push them and the car would slow, then the pedal would go down more and the car would stop. Didn't see any brake fliud leaking out
Won't have time to get into it until Monday.
Any ideas? I know I screwed somethng up.
Old Jan 16, 2014 | 08:01 PM
Possibly a brake spring came off?
Old Jan 16, 2014 | 08:22 PM
Redog's Avatar
Kinda sounded like a spring.
I was kinda cranking down on the one lever
Old Jan 17, 2014 | 06:10 AM
rjohnson442's Avatar
Mr. Johnson
X2 brake spring popped off and the secondary shoe isn't engaging until the the primary shoe gets pulled on hard enough to unseat it and rub.
Old Jan 17, 2014 | 03:21 PM
76olds's Avatar
Hookers under Hood
If the brake lite is on then the wheel cylinder is extended out and may start to leak due to a spring popping off, The pedal may jump back at you if the spring gets caught between the shoe and drum be careful.
Old Jan 18, 2014 | 02:50 AM
rustyroger's Avatar
'87 Delta 88 Royale
Why did you have to hit the drum with a hammer to get it back on?. Could be you dislodged the lining from the shoe in the process without realising.
A broken spring wouldn't affect brake travel, but you might well have a biding brake, if the lining came off you would have a sudden increase in pedal travel.
Seems like your dual circuit brakes are doing their job, and telling you so.
Roger.
Old Apr 17, 2015 | 01:17 AM
Redog's Avatar
Sorry I never updated this
The loud ping noise happened because the brake line for the rear brakes just snapped. I needed to get a new brake line installed for the rear axle. Car was due for inspection anyway, which is would have failed for the brake line anyway
Yes the brake was broke
1BAD71455
May 22, 2025 05:56 PM
therobski
Oct 25, 2014 12:16 PM
Macadoo
Aug 7, 2014 10:52 PM
wolskara
Sep 14, 2010 09:42 PM
