hoses hot, lever opens louver door, cabin cold.
Old Nov 26, 2023 | 09:34 AM
aronukmale's Avatar
Unhappy hoses hot, lever opens louver door, cabin cold.
1982 Oldsmobile Delta 88 Royal Bromham 4.3L gas. New water pump, hot top hose, back flushed heater core, both hoses hot,
removed the glove box, extra rush of air when the lever is pushed to the hot side, and top lever on the heater setting.
Air is cold.
Where to go from here?
Old Nov 26, 2023 | 10:05 AM
Start by telling us if this is a manual A/C or Comfortron
Old Nov 26, 2023 | 11:37 AM
Sugar Bear's Avatar
If both hoses stay hot the heater core may be air bound or clogged. The supply should be hot/engine temp, the return cooler/warm.
Old Nov 26, 2023 | 04:44 PM
aronukmale's Avatar
Manual a/c-lever must be moved on panel.
Old Nov 26, 2023 | 04:46 PM
aronukmale's Avatar
I was wondering if the top hoses and heater core hoses could just be hot from the engine itself?
I was able to put water into both pipes of the heater core-to flush.
Old Nov 28, 2023 | 06:14 AM
rfpowerdude's Avatar
Hot water control valve?
Old Nov 29, 2023 | 03:54 AM
aronukmale's Avatar
Turns out water hose pressure was not enough. Visit to Larrys Radiator and high pressure hose flushed heater core and fixed it. Thanks Guys!!
mks
May 16, 2022 11:58 AM
Niels67
Mar 16, 2014 03:01 PM
Armando S Nortez
Nov 15, 2013 08:43 PM
FinkD88
Mar 5, 2013 09:35 AM
deltaroads
Dec 8, 2010 02:48 PM
