Headlights out on 75 delta88
Old Jun 23, 2016 | 05:28 PM
filupsd@gmail.com's Avatar
I've had my Delta 88 convertible for about 20 years. I haven't had to do much beyond maintenance to this point. Last summer the headlights wouldn't come on. All other lights work great but no headlights. I don't drive it at night much so I didn't worry about it but this year I want to fix them.
I looked at the fuse panel and didn't see a fuse is that correct? I also read about a breaker and/or relay. Where are these located?
Any help would be helpful. I have a diagram but I'm not good with electrical diagrams.
Thanks David
Old Jun 23, 2016 | 07:11 PM
Check the voltage at the dimmer switch feed wire. If you have no voltage there, work your way back to the headlight switch.
Old Jun 24, 2016 | 07:37 AM
Thanks David
The headlight switch has an internal self-resetting circuit breaker.
Start troubleshooting at the dimmer switch on the floor. There is a three wire connector with blue (power from the headlight switch), brown (power out to the low beams), and green (power out to the high beams) wires. Pull the connector off the switch and see if you get +12V on the blue wire with the headlight switch on. If you do, the headlight switch is fine, if not, the headlight switch is likely the problem.
If you do get power on the blue wire, jumper from blue to brown with a wire and see if the low beams come on. If they do, replace the dimmer switch. If not, find out why.
Are you SURE all the headlight bulbs are good?
Old Jun 24, 2016 | 07:59 AM
76 Regency's Avatar
I'm with Joe. Start with the obvious like the bulbs themselves but then move onto the dimmer switch. I just had this happen on a '75 98 I was working on. Turned out to just be the dimmer switch and the lights are fully functional again.
Good luck!
Old Jun 25, 2016 | 03:43 PM
Thanks guys I will work on this tomorrow. Where is the best place to get a dimmer switch?
Old Jun 25, 2016 | 03:51 PM
At your local parts store or rockauto for under $10.
Old Jun 25, 2016 | 05:30 PM
svnt442's Avatar
Also if all else fails, check the ground wires from the lights to the header panel. If those get corroded the lights won't work.
Old Jun 26, 2016 | 07:21 AM
76 Regency's Avatar
Rock Auto: http://www.rockauto.com/en/catalog/o...er+switch,4340
Old Jul 14, 2016 | 06:16 PM
Northern Custom Cruiser's Avatar
Gearhead in training
Im with joe as well, had the same issue and it was the dimmer switch
LJ72Cut
Feb 23, 2016 11:06 AM
bigdooly
Sep 11, 2015 08:54 PM
Cutlass.Don
Sep 17, 2010 03:05 PM
EdsDelta
Jul 22, 2004 11:46 AM
<CTWalneck>
Jan 12, 2004 12:05 PM
