fuel gauge moves 1/4 in time with blinkers
Old Jun 14, 2014 | 01:54 PM
1964super88's Avatar
When blinkers are on gauge moves up and down with the blinker, about 1/8 tank each way, also when the headlights come on, the gauge drops 1/4 tank. Had the sender out and it tested to spec. Cleaned all connections at sender, and it did not get any better. Any Ideas?
Old Jun 14, 2014 | 04:56 PM
Possibly a loose or bad ground at the cluster.
Old Jun 15, 2014 | 02:35 PM
Tedd Thompson's Avatar
X2 sounds like a bad ground somewhere. Has there been a repair (cut and splice) on the gas line. I'm not familiar with your model car but some models are grounded through the gas line or it is just back feeding from a bad ground in the turn signal or lights....Tedd
Old Jun 16, 2014 | 03:53 AM
rocketraider's Avatar
Oldsdruid
Common problem on 63-64. Check grounds on the instrument cluster. All of mine do it and it's just not been enough of a priority to disassemble the dash and pull the cluster, though it's not really a bad job.
JPMDaddy
Jan 31, 2020 04:01 AM
truerollers
Feb 28, 2017 01:00 PM
Sully69
Mar 9, 2013 08:16 AM
rmoths
Jul 1, 2012 11:24 AM
mike623
Jan 20, 2011 12:57 PM
