Engine and interior swap ???
I recently picked up a 65 jetstar 88. It came with a 403 but not hooked up. I seen somewhere on here that it will "bolt" right in with the exception of the water pump/radiator issue. My question is; do I get motor mounts for the engine or the car? Also, I'm not digging the bench seat with the column shifter. Are there any buckets with a floor shift that I can put in that isn't going to be a PITA. Thanks
The 65 Jetstar came with a 330 small block engine. Externally the 403 is exactly the same. You should have no issue with radiator or water pump since it is a 65. The engine mounts would be the same as original. You would need mounts for a 65 Jetstar 88. Bucket seats and floor shift were available (possibly standard) in 65 for the Jetstar I and Sfire and possibly optional the Jetstar88 as well.
Not sure what your question is. A TH350 is the same overall length as the original two speed Jetaway and is a common swap. It's a complete bolt-in except for the kickdown cable.
