Electric choke thermostat upgrade
Old Mar 26, 2018 | 09:32 AM
1969 88 Convertible's Avatar
I followed Joe Padavano's electric choke upgrade instructionsby replacing the original single pole oil pressure relay with the three pole unit. So far so good... Unfortunately the coil in the single pole electric choke that I purchased on Ebay rotates counter clockwise when heated rather than clockwise.
I contacted the vendor (USCarburators) but they do not have a similar item that rotates clockwise. Does a single pole electric thermostat exist for my application, and if so what is the part number?
I did locate an upgrade kit at Mike's Carburetor but there's is a complete kit with two wires/poles and costs $40.00 which I am happy to pay if needed.
Also, is it possible to remove the coil on my existing electric choke and flip it around to make it rotate clockwise? The coil is really really pressed on tight and I am concerned that I could damage it....but it only cost 15.00... All responses are appreciated...
Old Mar 26, 2018 | 10:39 AM
What carb are you running? Typically the Qjet coils go one way and the 2GC coils go the other way. Unfortunately I don't know what you mean by "clockwise" or "counterclockwise", since you didn't specify which way you were looking at the coil.
The Qjet coil looks like this:
I like to use Standard Motor Products CV329 (from a mid-80s Chevy truck 454) to convert to electric:
Depending on how you want the choke to respond, there's also CV362 (from a mid-80s Buick V6 DualJet):
The 2GC coil looks like this (and runs in the opposite direction):
Unfortunately, I have not found an electric choke thermostat that runs in the same direction as the 2GC coil. I have found a carb parts vendor who says to just pull the coil off and reverse it. They also sell just the coil in case it gets damaged.
EDIT: OK, found it. Mike's sells a single wire electric choke thermostat that runs the other way.
Old Mar 26, 2018 | 11:47 AM
Thanks for your reply Joe...I bought a rebuilt Rochester 2GC to replace the Original 2GC which was filthy and in need of a rebuild. I spoke with Mike's Carb this morning and they said they didn't have the thermostat that you found. Do you happen to know the part Number? By the way the thermostat was installed incorrectly on the rebuilt carb (far left)...I did just manage to remove (and flip) the electronic thermostat winding with the aid of a bench grinder applied to the center pin so I am anxious to try it out on the car...
Old Mar 26, 2018 | 11:52 AM
Part Number:TH1057
The P/N was in the link I provided above.
Old Mar 26, 2018 | 11:54 AM
Part Number:TH1057
DUH.... I see that now...thanks....
Old Mar 26, 2018 | 12:08 PM
I just found Standard Motor P/N CV291, about $13 at RockAuto.
Old Mar 26, 2018 | 12:27 PM
Damn Joe that's great.. I Just ordered one....thanks!
BTW...a pic of my work in progress that I took today...I'm going for the clean look and have removed all body trim... Ran into a minor snag with TTO,s rubbing on front ribbed brake drums so I installed washers on the lugs, but i relly need to upgrade to longer studs now...
Old Mar 26, 2018 | 01:28 PM
Sharp looking car. What size TTOs do you have in the front? I've got no problems with the 15x7 TTOs on the front of my 67 Delta with the original drums.
Old Mar 26, 2018 | 01:34 PM
Thanks for the compliment... 15x7 front 15x8.5 rear
240 Gordy
Oct 11, 2020 10:04 AM
ros6872
Aug 28, 2012 09:32 AM
Jun 1, 2012 10:18 AM
rroth01
Jun 28, 2011 08:45 PM
cutlass47
Apr 17, 2009 07:02 AM
