Disc Brake Kit ?
Disc Brake Kit ?
Hi Guys I,m in the middle of re doing , My 66 Dynamic 88 , 4 DR, and was wondering if any off you know of any available Disc Brake Conversion Kits
that would be near enough Bolt On ?
The Brakes on my Car kinda suck at the min , and need some serious attention , I just thought it may be a better investment to go Disc .
I should have mentioned that. I am converting to 15" rims on my 57. I don't think you will find a disc brake conversion that will fit the 14" wheels. At least that is what I found out in my search.
Stainless steel brakes corporation, www.ssbrakes.com. They do have a kit for your car that allows you to keep the 14x7 wheels. Not cheap and I am not sure that it is exactly what you are looking for but check it out anyway.
I really don't know what the problem is with these aftermarket brake companies. The factory disk brakes (yes, offered 67-70, but the 65-66 suspension and spindles are interchangeable) came with 14" wheels. Just remember that in the 1960s GM made wheels that would not clear any disk brakes due to the contour of the backside of the wheel. Thus you will often hear about disk brake and non-disk brake wheels in that time frame.
Quick update.
I am off work today , an decided to take a look at the front brakes on the 66 Dynamic ,
pulled the pssenger front drum off ,
Now I know why its not stopping very well,
Leaking Wheel Cylinder
Havent even checked the rest , but i,m sure it,s time to do the 4 off them .
Money is tight at the min (Thats a familiar story) so I,m gonna have to fix the drums , instead off going to discs at the min
Any one got a suggestion, where a good place is to get new wheel Cylinders ?
Oh and also, There seem to be 2 differt size bores being sold , how would I know which is mine , without pulling it all apart ?
Quick update.
Thanks for the reply
So would I be right in assuming , That I could use either one ?, without any modifications ?
and if you were doing it , would you just replace both front ones , or just do all 4 at the same time , to freshen up the brake system ?
The Reason I ask is I,ve only had the Car 6 months , have done a tone off work on it already and I cant honestly say when the Brakes were done last,
Joe I just went to the parts store today , looking for some Brake Cylinders , they dident have any , But they did have a rebuild kit,
I bought 2 , just to see if I could rebuild mine .
God what a Dirty Job , lol
ah wel, thats part off the fun
I only had time to rebuid the front passenger side cylinder, havent reinstalled it yet , tomorrow
I,ve never worked on these before so its a learning curve
I just wanted to do it to say i had done it myself , an save some green is always a good thing .
By the way , I suppose I better go get some spring Pliars tomorrow , I cant see me being able to get the springs back on the shoes without them ?
Hey Joe
Just back in from rebuilding that brake cylinder ,
Yes I bought a Hone at the same time , and cleaned the bore up like new ,
I had never worked on Drum Brakes before , an certainly nothing like these Monsters !!!
I went an got the spring Pliares , they came in very handy.
Anyway
It took me a good while to clean everything up nice , an had to see how it all worked ,
but in the end I got it all put back together , an had my
buddy pump up the brakes while I bled (and from cuts as well , lol)
Brakes are super good now
May not even bother with the disc,s for a long time
Thanks for all the help
I feel it was well worth doing the job myself , after all, it saved a load off money, which I can spend on doing some more jobs on the Car
Anyway
Mocephus
October 1st, 2021 09:45 AM
