Design problem or manufacturing defect? (window track)
Old Apr 7, 2016 | 07:12 PM
illumined's Avatar
1978 Ninety Eight
An ongoing problem has been that the window would get stuck in the down position if the door is closed and the window is more than halfway down, it will come off the regulator causing it to get stuck in the down position. As it turns out the window track is actually wider towards the bottom than it seems like it should be, which allows the glass to move, breaking the plastic clip that holds it to the regulator. At first I thought this might be a manufacturing defect, but while having the regulator replaced on the passenger side (it was the original and starting to decay) i found out it also has that problem so now I'm not so sure.
Has anyone else had this problem? I've got an '88 Delta 88 coupe.
Old Apr 7, 2016 | 07:35 PM
RROLDSX's Avatar
Sounds like roller and/or adjustment problems. You need to take your door cards off and study the problem carefully. There are a few adjustment areas in the mechanisms.
Old Apr 7, 2016 | 08:01 PM
Sounds like this is for an '88 88, with which I have no experience, but in dealing with other cars, I have found that almost all window-related parts are bendable with the right tools and a bit of determination, so I suspect that you could tighten the lower tracks, or bend other parts, in addition to the usual adjustments, once you've got a good idea of the forces acting on the parts.
Old Apr 8, 2016 | 05:04 PM
illumined's Avatar
1978 Ninety Eight
I looked at it myself and track itself is definitely wider at the bottom than it is at the top. I could be using the wrong terminology, it could be called the channel I think, but that metal piece the window slides up and down through. Number 4 on the diagram below. My first thought was to replace it, but if it is a design problem then I'm not sure that would do any good. Any thoughts?
That's an idea, although I must admit I am a bit reluctant to go that route unless I can be sure there's no alternative.
cwb442
Nov 17, 2014 09:39 AM
f-85
Jan 16, 2012 06:10 AM
knighthawk
Sep 25, 2011 06:05 PM
exoldsemployee
Jul 2, 2011 07:31 PM
yammiman
Nov 17, 2009 02:52 PM
