checking my ignition coil - resistance values?
Old May 25, 2013 | 06:52 PM
pbob42's Avatar
Member
Lost spark on my 63 super - think it is the coil. Measures 1.6 ohm from outside post to outside post and 8K ohm from center to outside post. One looks high and one looks low but I don't have the specs. Can you help me out here?
Have 12 volts to positive side and pulsing voltage on the negative side as I turn the motor so I think my distributor is good. Just nothing coming out of the center connector of the coil to the distributor.
Old May 25, 2013 | 07:11 PM
What is your point gap set to, should be around .019
Old May 25, 2013 | 07:19 PM
pbob42's Avatar
Member
I will check that but I figured if the negative side of the coil was flashing 12v that the points were right. Thanks for the heads up.
Old May 25, 2013 | 07:39 PM
Just test the coil the old fashioned way:
Put a plug wire in the top of the coil,
Connect the other end of the plug wire to a spark plug resting on a good ground,
Disconnect the wire on the (-) coil terminal,
Connect a length of wire to the (-) coil terminal,
Turn on the ignition,
Touch the other end of that wire to a good ground for an instant and pull it away.
When you pull the wire away from ground, the spark plug should produce a good, hot spark.
Old May 25, 2013 | 07:45 PM
pbob42's Avatar
Member
I can do that
Old May 25, 2013 | 09:25 PM
BILL DEMMER's Avatar
Just the facts...
while your ohmmeter checks show that your coil is probably good, that method of testing is a static method for continuity checking. the procedure for dynamically checking via actually having it generate a spark is a more valid test, as it will show if there is a high-voltage breakdown inside the coil. a weak, yellow/orange spark is evidence that the windings are breaking down. you want a white/blue spark across a .035" gap, as that is what you're gap should probably be.
most people won't have a high-voltage probe, so i won't go there...
bill
Old May 26, 2013 | 04:02 AM
I reserve those for particularly naughty play dates.
Old May 27, 2013 | 10:44 AM
pbob42's Avatar
Member
Think someone was playing a joke on me and scrambled up my sparkplug wires. What is the firing order?
Old May 27, 2013 | 11:15 AM
It's cast right into the intake manifold: 1-8-4-3-6-5-7-2, COUNTER-clockwise.
Old May 27, 2013 | 11:32 AM
pbob42's Avatar
Member
mine says - 18736542 - thanks.
Old May 27, 2013 | 05:50 PM
Just the facts...
got a pic of that??
1-8-4-3-6-5-7-2 is 100% correct, guaranteed. <<<good thing it wasn't a money back guarantee
bill
Old May 27, 2013 | 06:42 PM
pbob42's Avatar
Member
Mine is a 63
Old May 27, 2013 | 07:18 PM
TripDeuces's Avatar
I'm guessing it's a 394, they have the 4/7 swap if I remember correctly
Old May 27, 2013 | 07:47 PM
He got ya! LOL
Old May 27, 2013 | 08:02 PM
... But you found the correct firing order, and can now check your distributor.
Sorry I gave you the wrong information.
Old May 27, 2013 | 08:31 PM
Just the facts...
i learned something else new today.
bill
Old May 27, 2013 | 08:37 PM
pbob42's Avatar
Member
Got it running - need to set my dwell correctly. New points have the condenser in the way and it is a pain to set the gap
Old May 27, 2013 | 09:01 PM
Just the facts...
remember, setting the dwell also affects the timing. you'll want to check the timing afterwards, just to be sure it's correct.
bill
Old May 28, 2013 | 03:12 AM
Doesn't the 394 have the "windowed" distributor cap?
You should be able to just set the dwell with the engine running, without using a feeler gauge or setting the gap.
Old May 28, 2013 | 06:11 AM
pbob42's Avatar
Member
I am trying to get it running so I can set the dwell. Pain the in butt setting the gap to get it to start. My eyes aren't what they used to be. Got it running for a minute but it was sputtering a bit and blew off the vacuum cap for the break booster. Turned it off, put the cap back on and she is not wanting to start up again.
My old points were easy to gap. I could slide my feeler gauge right in.
I will put some time in on it this morning and be all dialed in.
Old May 28, 2013 | 07:07 AM
pbob42's Avatar
Member
Got my dwell set - all is good. Thanks for the help.
Old May 28, 2013 | 07:11 AM
Great!
Old May 28, 2013 | 10:38 AM
Your dwell needs to be right at 30, no more no less.
woodie582
Feb 8, 2013 06:57 PM
RandyS
Sep 12, 2012 02:40 PM
jag1886
Jan 12, 2011 07:37 AM
Muskego Jeff
Sep 28, 2009 06:33 AM
New'n72
Oct 10, 2007 04:42 PM
