Best place for replacement seatbelts
Old Feb 9, 2008 | 06:48 AM
rutsski's Avatar
Anyone know about the best place to find replacement seatbelts?
Old Feb 9, 2008 | 06:57 AM
2blu442's Avatar
Seatbelts
If you want used ones post a parts wanted ad here. You can also monitor ebay but depending on which buckles you want they may be going for a pile of money. A buddy of mine bought new webbing material and had a new set stitched up for a reasonable price. If you have good hardware but rotten fabric that might be an alternative.
Old Feb 9, 2008 | 10:48 AM
I believe you can get generic ones at your local auto parts store. You also might check out Kanter auto parts for generic seat belts.
Old Feb 26, 2008 | 07:17 PM
TommyDelta88's Avatar
Hi, I think this is my first post so I'll chime in for this one. I retrofitted shoulder belts in a car that only had lap belts. I was happy with the service and pricing. The site is www.andoverrestraints.com I also have 63 T-Bird that my wife refused to drive in without shoulder belts. I did some searching and found this company. I'm going to put rear seat belts in that car also. Good luck and hopefully they willhave what you need.
Old Feb 26, 2008 | 09:09 PM
Jolly Green's Avatar
Car Craft did a story on a company to order replacement belts. Might want to check out their website.
Old Jul 8, 2008 | 12:29 AM
tjjammer's Avatar
Shoulder belts
I am looking at picking up a 68 convertible cutlass yet the wife wants to ensure that there are shoulder belts all around. Has anyone installed shoulder belts in the rear seats? I suppose I could go with harnesses all around so if anyone has gone in that direction, I would appreciate the info also.
T.
Old Jul 8, 2008 | 05:13 PM
I don't believe you could easily install 3 point harnesses into a car not designed for it. The problem would be that you don't know if the rear pillar is strong enough to serve as a mounting point for a safety harness. Also, if you used a 3 point harness with one belt and and two anchor points you would have trouble getting the pre-tensioner and locking function to work since they use gravity, mounting position, and centrifugal force to operate.
ddd777
Jun 17, 2014 07:27 PM
kitfoxdave
Body work
Jun 6, 2013 07:05 PM
raw442
Jun 3, 2012 06:46 PM
sexycutlass69
Nov 8, 2007 09:33 PM
PhreakWenCi
Sep 1, 2006 12:37 PM
