'84 Delta 88 transmission Attn: Oldsfan
Old Sep 19, 2006 | 11:39 AM
ztim's Avatar
Hi...the automatic transmission drip is not coming from the pan as I thought (drain bolt). Recall the tranni is a MV9
Ok. Where the front of the drive shaft connects, there is a crossbar. Support I think. In the center of that there seems to be a bracket with a recessed bolt. I think the bolt holds it together with some kind of rubber block. It is that bolt that has a drip to it.
Could it be coming from the transmission pan gasket if there is a leak? I topped it off with some transmission fluid for high mileage transmissions with a stop leak additive.
Old Sep 20, 2006 | 09:27 AM
Joel n's Avatar
not to sound dumb, but i was told when i got my 78 delta, that it had a leak at the trans pan as well. he had some mechanic look at it. i took it to work and put it on my hoist, and found it was the speed-O cable. there is a small O ring that seals it all up, and my leak was coming from there. Now my trans is a 350 TURBO, and the cable is on the drivers side, the fluid runs down the cable, drops on the exhaust, and runs back a bit till it drips off..
Old Sep 20, 2006 | 09:50 AM
ztim's Avatar
Thanks guys. I will check out both today.
Old Oct 7, 2006 | 02:20 PM
ztim's Avatar
For some reason the drip stopped. Strange.
WMACHINES
Mar 7, 2014 08:49 AM
jeffreyalman
Jun 8, 2011 05:58 PM
WhatIf
Feb 10, 2010 01:13 PM
J-(Chicago)
Mar 22, 2009 12:06 PM
66 Olznut
May 26, 2008 10:57 AM
