82 Olds Delta 88 hub Lock key needed and identified
Old Aug 16, 2019 | 01:36 PM
82olds88's Avatar
Hello everyone i am new to this forum and own a 97 olds cutlass supreme and 82 Olds Delta 88 Royale and it came with no key for hubcap locks. The locks have 7 notches and i bought a key marked A but the locks are a little bigger than the key and doesn't fit , does anyone know where i can get the right key and what Letter or color its is . Thank you. Try to post pics soon
Old Aug 16, 2019 | 02:22 PM
CRUZN 66's Avatar
Olds Fever
If you look real close there should be a code stamped somewhere on the lock nut... There are several different codes and/or colors available for 82, so that in and of itself will not help you unless you know the code or color of the nuts you have... A photo by itself will be too difficult to determine the pattern required...
Old Aug 16, 2019 | 03:26 PM
82olds88's Avatar
Thanks for the reply i didn't see anything but i'll try to clean them up maybe it will reveal something
Chesrown 67 OAI
Mar 24, 2015 10:05 PM
ramblinwreck
19
Jul 28, 2013 07:33 PM
69'442
Jan 16, 2013 12:58 PM
mscofer
Apr 4, 2010 06:35 PM
