'75 transmission problems
Old Apr 25, 2014 | 07:24 AM
1lowdelta88's Avatar
Rookie
Hello all! I had my 75 delta 88 at a shop getting some bugs worked out and they replaced the transmission pan gasket, so I'm assuming they drained the fluid out and put all new in. After I got the car back it doesn't seem to want to shift out of first gear. Thankfully the garage was close to home so I didn't have to drive it far.
Reverse was fine, neutral was still in the same place, as well as park. But when I put it in drive, wouldn't go out of first.
Anyone have any thoughts or opinions on this or what I should check before I pull the engine and tranny?
Old Apr 25, 2014 | 07:36 AM
rocketraider's Avatar
Oldsdruid
Fluid level IS normal, right?
If the fluid level is normal the simplest thing is check the vacuum line to the vacuum modulator (round gizmus on side of trans with a steel and rubber line going to it). If the vacuum line is disconnected or crimped a THM will often not shift out of low or will be a very delayed upshift.
Past that it's probably a stuck governor.
Old Apr 25, 2014 | 09:25 AM
X2 on above. The modulator also needs full manifold vacuum to operate correctly.
Old Apr 25, 2014 | 06:30 PM
Rookie
Thanks guys! I'm hoping you're right. I'll have to check when I get the car back.
So you don't think it's anything serious? I once heard that some shops won't change transmission fluid after so many miles for some reason. Not sure why
chasman414
Jun 25, 2020 07:05 AM
bwichman
May 10, 2010 03:01 PM
1964OldsmobileF-85V84Door
Sep 24, 2008 12:09 PM
toyktdlgh
15
May 14, 2008 06:52 AM
155thINF
Sep 20, 2006 10:15 PM
